Most Obscure Prius Facts (Way out there)
Discussion in 'Gen 2 Prius Main Forum' started by 200Volts, Nov 20, 2006.
  1. barefootmatt
    barefootmatt New Member
    25
    <div class='quotetop'>QUOTE(chogan @ Nov 21 2006, 05:29 AM) [snapback]352448[/snapback]</div>
    Ah, not so! A Prius plus an Insight will carry 6 adults more efficiently than two Prii.
  2. GeronimoPFudgemuffin
    62
    <div class='quotetop'>QUOTE(Barefoot Matt @ Dec 5 2006, 02:43 AM) [snapback]357845[/snapback]</div>
    Is the Insight "currently available?" I was told (by a salesman) that it wasn't in the US lineup. If not here in the US, is it available elsewhere?
  3. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    the insight is no longer manufactured. used is the best you can get today
  4. Beryl Octet
    Beryl Octet New Member
    1,293
    Abingdon VA
    <div class='quotetop'>QUOTE(DaveinOlyWA @ Dec 5 2006, 09:22 AM) [snapback]357887[/snapback]</div>
    It just went out of production in Sept. '06, seems like you still might find a new one at a dealer somewhere.
  5. Stev0
    7,201
    1,074
    Northampton, MA
    2022 Prius Prime
    Actually, the Prius was my second choice. I wanted an Insight (better MPG, plus it looks even cooler), but the Honda dealer didn't have any and wouldn't be getting any more. So I went across the street to my Toyota dealer and have been happy ever since.
  6. InfideNino
    InfideNino New Member
    44
    <div class='quotetop'>QUOTE(Sarge @ Dec 3 2006, 07:08 PM) [snapback]356997[/snapback]</div>
    When I want to switch to the map screen during a phone call, I press the Dest button first (next to the MFD), and then the Map button. This way, you can go to the map screen without Jill interupting your call. Of course, you'll have to watch the MFD for instructions because Jill won't talk to you until you end your call (she can be kind of grumpy sometimes).
  7. Sarge
    Sarge Senior Member
    1,325
    784
    Milton, Ontario, Canada
    2023 Prius Prime
    XSE Premium
    <div class='quotetop'>QUOTE(InfideNino @ Dec 5 2006, 11:37 AM) [snapback]357965[/snapback]</div>
    Really... I've never tried that! Thanks for the tip!
    This is such a great site! B)
  8. Stev0
    7,201
    1,074
    Northampton, MA
    2022 Prius Prime
    You call her Jill? I call her Holly (from Red Dwarf).
    Data Daedalus likes this.
  9. Sarge
    Sarge Senior Member
    1,325
    784
    2023 Prius Prime
    XSE Premium
    <div class='quotetop'>QUOTE(Stev0 @ Dec 5 2006, 01:52 PM) [snapback]358047[/snapback]</div>
    I call her Jill as well, based on reading a thread a read a long time ago where someone was investigating the DVD and found a voice file called vfjill or something like that, to which the general concensus around here was that it meant "voice-female-jill". I guess that's what the engineers called her. Or something like that. :lol:
  10. windstrings
    windstrings Certified Prius Breeder
    6,280
    378
    Central Texas
    I"ve noticed if you traverse a path enough times "I don't know what the majic number is" the destination setting will choose your preferred diversion rather than the default route it gives you at first.
    For instance if you plug in a destination and its 50 miles away and it likes to keep routing you through a small town down its business district, but you always divert around it...
    After making the trip several times and the navigation will finally figure out thats your preferred choice and will start routing you that way when you plug in that same destination.
  11. Mr07touring
    Mr07touring New Member
    45
    Minn
    Cruise control speed can be increased or decreased by one MPH by tapping the cruise lever briefly either up or down respectively. Prior toyota's would do 2 or 3 MPH changes, so this greater control I found useful for matching speed with a truck (following at a suitable distance of course) or other vehicle while interstate droning.
  12. cwerdna
    cwerdna Senior Member
    12,544
    2,124
    SF Bay Area, CA
    <div class='quotetop'>QUOTE(Mr07Touring @ Dec 5 2006, 11:15 PM) [snapback]358343[/snapback]</div>
    Which part is obscure? The Prius increments being by 1 mph or the (supposed) 2 or 3 mph of prior Toyotas? My former 02 Nissan Maxima and 04 350Z go in 1 mph increments. I'm not sure when automakers started doing this though.
  13. sseres
    sseres New Member
    37
    A square kleenex box fits perfectly in the front of the storage compartment (whatever you call it -- the thing between the two front seats where you can throw all your change and stuff).
  14. Sarge
    Sarge Senior Member
    1,325
    784
    2023 Prius Prime
    XSE Premium
    <div class='quotetop'>QUOTE(windstrings @ Dec 5 2006, 09:56 PM) [snapback]358257[/snapback]</div>
    Hmmm... I must say that mine definitely does not 'adapt'.
    In the 7 months I have been driving the car and using my navi for my daily commute - during which I *never* follow the suggested route for traffic reasons - it has never directed me any differently even though I take virtually the same route everyday. The only time I get different directions if I choose a different route type (Quick2, Short, or Detour route).
    Is there some "intelligence" setting hidden somewhere? Would be cool if there was. ;)
  15. windstrings
    6,280
    378
    Central Texas
    <div class='quotetop'>QUOTE(Sarge @ Dec 6 2006, 08:40 AM) [snapback]358394[/snapback]</div>
    I would definately like to know more about the parameters of this. I live in a neighborhood that off the beaten path so it always says "you will be taking road without complete guidance etc etc", and the faint line it gives you was always to another exit. I never took that exit. Also when coming home, it would choose the default entrace it liked.
    Now thats its magically changed, it routes me through my favorite exit when leaving or coming home.
    I'm not trying it on some "midroute" detours I"ve just started doing.. it may never work on "established" routes. Maybe it only works on those obscure "off the grid" routes it knows it doesn't have nailed down.
    <div class='quotetop'>QUOTE(Mr07Touring @ Dec 6 2006, 01:15 AM) [snapback]358343[/snapback]</div>
    Hey.. welcome to the forum.. I for one was not aware of this feature and appreciate you bringing it to my attention... :rolleyes:
  16. Stev0
    7,201
    1,074
    Northampton, MA
    2022 Prius Prime
    <div class='quotetop'>QUOTE(windstrings @ Dec 6 2006, 11:44 AM) [snapback]358447[/snapback]</div>
    It definitely works on "on the grid" routes. The first few times I had to drive into Boston, it said, "Hey, you want to take the scenic route that will get you there in 2:50!" Eventually it figured out I DO want to take the toll road that will get me there in an hour and a half.
  17. Sarge
    Sarge Senior Member
    1,325
    784
    2023 Prius Prime
    XSE Premium
    Interesting. Since I live near the "centre of the universe" (a.k.a. Toronto, but for the record I will always be a Montrealer!), I very seldom go into an area where turn by turn guidance is not available. In fact, I have done it exactly once in my 7+ months of ownership.
    Obviously you have an '06 as well so mapping DVD could not have changed, and I am sure it is fairly safe to assume no other servicing/software updates would have been applied that may affect the behaviour.
    I wonder if anyone else driving regularly in an "unguided" area may have noticed a similar behaviour...?
    PS - another quirk of the Navigation is that in Canada "Jill" doesn't pronounce the highway numbers. They are all simply called "Freeways", or at least all the ones I've driven on, anyway. It caught me off guard the first time I drove to Buffalo, NY and she told me to "stay right onto the I-90"! :huh: :lol:
  18. PriusRos
    PriusRos A Fairly Senior Member - 2016 Prius Owner
    1,973
    218
    Rockville, MD
    To lift the rear windshield wiper away from the car so you can properly wash the hatch window underneath, remove the little plastic cover at the base of the wiper.
  19. hill
    8,805
    <div class='quotetop'>QUOTE(Stev0 @ Dec 5 2006, 12:13 PM) [snapback]357946[/snapback]</div>
    And, you got rear seats!
  20. cliffdvr
    cliffdvr New Member
    I just discovered that you can turn off the stereo by holding the "mode" button on the steering wheel down for a few seconds.
