Most Obscure Prius Facts (Way out there)
Discussion in 'Gen 2 Prius Main Forum' started by 200Volts, Nov 20, 2006.
  1. Tideland Prius
    16,551
    <div class='quotetop'>QUOTE(kimgh @ Dec 9 2006, 06:34 PM) [snapback]359930[/snapback]</div>
    LOL... we're so used to keyless entry that we forgot the old fashioned way of locking haha.
    Yes, it only locks that door.
  2. Schmika
    Schmika New Member
    1,617
    Xenia, OH
    I found in my 2005 that, even if the outside temp is below freezing, when you reduce the inside temp thermostat to 65, it goes to max air conditioning.
  3. windstrings
    windstrings Certified Prius Breeder
    6,280
    378
    Central Texas
    <div class='quotetop'>QUOTE(Schmika @ Dec 10 2006, 08:18 PM) [snapback]360203[/snapback]</div>
    Does it do that even when the inside car temp is below 65 when you first get in?
  4. MPG > HP
    MPG > HP Junior Member
    58
    <div class='quotetop'>QUOTE(engunneer @ Nov 21 2006, 01:24 PM) [snapback]352693[/snapback]</div>
    Ok, Say your 12 volt battery runs out, would it be possible to "jump start," by going up to around 30MPH in EV mode, then shifting to the "B" engine brake mode to turn the ICE until it starts and in turn, make the alternator recharge the 12 volt?
  5. MPG > HP
    58
    <div class='quotetop'>QUOTE(LMA @ Nov 27 2006, 08:36 PM) [snapback]354673[/snapback]</div>
    I use the Calendar/Memo function to do this, by noting Tttt Ggg.g Aaa.a Eee.e, where "ttt"=Trip miles, "gg.g"=Gallon, "aa.a"=Calculated MPG and "ee.e"=Computer estimated MPG. When you do this you also see your fillups graphically in Calendar view. I can readily see that I routinely fill up every 6 days. This makes me ask, is there any way to download memos into an Excel spreadsheet?
  6. windstrings
    6,280
    378
    Central Texas
    <div class='quotetop'>QUOTE(MPG > HP @ Dec 10 2006, 11:13 PM) [snapback]360257[/snapback]</div>
    Interesting concept... if your battery would be so dead as to not be able to boot a computer, your not going anywhere..... EV mode or not.
    The Computer has to be on before "anything" works in the way of propelling your car to the best of my knowledge.
    But could someone pull you with a rope and do that..is another question?
    I just carry an extra booster battery you can get for 50.00 bucks that has 1100 cold cranking amps "far more than you need to boot a computer" and a light and airpump all in one... that way no one is messing with your car that doesn't know what they're doing, and you will never be tempted to help someone out by jumping them off your car.
  7. Sarge
    Sarge Senior Member
    1,325
    779
    Milton, Ontario, Canada
    2023 Prius Prime
    XSE Premium
    <div class='quotetop'>QUOTE(MPG > HP @ Dec 11 2006, 12:59 AM) [snapback]360266[/snapback]</div>
    Interesting idea for Calendar use, which (IMHO) is a pretty useless feature in itself.
    I know appointments can be programmed in the calendar and tie to the a NAV destination, so it will prompt you when you start the car, but since there is no time associated, it seems minimally useful as I generally make more than one trip per day. Or am I missing something?
    As for the Excel question, I highly doubt there is any way to download Calendar data, into Excel or otherwise. Which further backs my opinion about this being a useless feature. :lol:
    I simply carry a PocketPC and track all my mileage, appointments, contact info, etc... in there. Much more elegant. ;)
  8. MPG > HP
    58
    <div class='quotetop'>QUOTE(windstrings @ Dec 11 2006, 04:25 AM) [snapback]360300[/snapback]</div>
    Thanks for the response! So are you confirming that the EV control systems all run off the lead/acid battery? Nonetheless, it's been my experience with other cars, that a battery's ability to crank and start a motor ends far above the amount of energy needed to run accessories and cpu's. Thus my thought that EV would still be available for getting up to push start speed, without external assistance. I don't think I'd ever find it necessary to carry around an extra battery as insurance for battery failure. Rather, just replace the OEM battery with a more durable/higher cranking amps one, once the OEM started showing signs of weakness.
  9. windstrings
    6,280
    378
    Central Texas
    <div class='quotetop'>QUOTE(MPG > HP @ Dec 11 2006, 10:52 PM) [snapback]360777[/snapback]</div>
    Nope.... I"m saying the EV needs the use of the computer to engage the car the same as when using normally to engage the engine. Until the Computer is up and running, you have nothing.
    Without the computer, I don't even think Accessories run? "not sure about that one"
    So if there is enough juice to boot the computer.... all else will work anyway, because the big traction battery comes into play to reimburse the 12V system anyway with its inverter.
    First computer, then EV or ICE.
    I know of no way to get the car moving without first the computer "which boots off of 12V".
    Someone will correct me if I"m wrong.
  10. orubin
    orubin Junior Member
    <div class='quotetop'>QUOTE(FieroGT @ Dec 3 2006, 04:56 PM) [snapback]357150[/snapback]</div>
    I wonder why we have a clock there at all. there is plenty of room next to the outside temp to display time.
    <div class='quotetop'>QUOTE(VABeachPrius @ Nov 20 2006, 08:31 PM) [snapback]352393[/snapback]</div>
    On 2007+, on the CDs that play MP3 disks, holding down or up for a few seconds will change to the next FOLDER on the MP3 disk (if it has multiple folders).
    --No 6 CD player in my car - but I create 10 folder MP3 disks, and it acts just like a multiple CD player for me. Now, if I could just get that damn motion sensor to let me look at the folders and songs while moving!!! Strange, I can view lots of info on the car, but seeing the name of the song I am listening to while driving, that is bad. Odd choice. (anyone know if there is a bypass for this?)
  11. Schmika
    Schmika New Member
    1,617
    Xenia, OH
    <div class='quotetop'>QUOTE(windstrings @ Dec 10 2006, 11:40 PM) [snapback]360215[/snapback]</div>
    Yes, it did on mine.
  12. windstrings
    6,280
    378
    Central Texas
    <div class='quotetop'>QUOTE(Schmika @ Dec 12 2006, 07:27 PM) [snapback]361273[/snapback]</div>
    Interesting..mine must do it too then..... I've never tried.
  13. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    integrating a clock on the MFD would not be that expensive, but adding the ability to adjust it might be. considering that a cheap LCD clock probably costs Toyota about a nickel, the decision is not hard to make
  14. Syclone
    Syclone Member
    540
    <div class='quotetop'>QUOTE(windstrings @ Dec 12 2006, 06:34 AM) [snapback]360817[/snapback]</div>
    Ok, you're wrong! :D Just kidding!
    Has anyone noticed that if you start the car at night, with the lights on, the light come on for a second or so, at a certain level. Then there is the hint of a click and the lights brighten. This is the safety relay between the high voltage and low voltage systems coming on, and the inverter powering up. This cannot happen until the computer (s) boot up. So, unless there is sufficient power coming from the low voltage system, nothing will happen, even if the car is rolling downhill at 50 MPH. (Of course, this couldn't happen either, because you couldn't get the system out of park)
  15. aaf709
    3,862
    2022 Prius Prime
    <div class='quotetop'>QUOTE(windstrings @ Dec 12 2006, 03:34 AM) [snapback]360817[/snapback]</div>
    I tend to think of the 12v battery to be like the CMOS battery you have on your motherboard.
  16. dachshund
    dachshund New Member
    Glide mode works at greater than 42 mph - does anyone else see this?
    This is the "no arrow" mode. I thought it was only possible at < 42 mph.
  17. windstrings
    6,280
    378
    Central Texas
    <div class='quotetop'>QUOTE(syclone @ Dec 14 2006, 12:52 PM) [snapback]362293[/snapback]</div>
    The low voltage system only powers accessories... and boots the computer.....
    <div class='quotetop'>QUOTE(dachshund @ Dec 14 2006, 11:41 PM) [snapback]362634[/snapback]</div>
    Your battery has to be fully charged..almost overcharged to get it to work.. like after coming off a long hill, the car is looking for an excuse to drain the battery anyway.... if your battery was that charged enough for this to happen and you simply pulled off the road and just sat there, your engine would most likely cycle to burn off the excess....
    Its called "super EV" and a few other names I can't remember...
    You can get it to work up to 65 or so, but its "very" short lived... once the battery gets to normal ranges it stops.... and the engine never turned completely off in the sense of no movement, it was churning with no gas....
  18. Schmika
    Schmika New Member
    1,617
    Xenia, OH
    <div class='quotetop'>QUOTE(dachshund @ Dec 15 2006, 02:41 AM) [snapback]362634[/snapback]</div>
    I don't remember anyone of authority saying you could not glide over 41, just that the ICE continues to spin and you cannot go EV mode only above 41.
  19. DieselConvert
    DieselConvert Member
    121
    Central Coast, CA
    Here's obscure:
    The sway bar has only one connecting link. After pulling the wheels to rotate at 5,000 mi., I couldn't find the link on the right rear axle. I placed a link for my '81 Mercedes 300D (the Z-shaped rod with threaded top and bottom) in front of the Pri's for comparison in the photo. The Pri's is behind the threaded top piece.
    Here's obscure:
    [attachmentid=5931]
  20. gupchurch1349
    gupchurch1349 New Member
    29
    <div class='quotetop'>QUOTE(DaveinOlyWA @ Nov 20 2006, 10:45 PM) [snapback]352401[/snapback]</div>
    <div class='quotetop'>QUOTE(TonyPSchaefer @ Nov 20 2006, 10:48 PM) [snapback]352403[/snapback]</div>
    The Earth is a three dimensional object. It could never be round. A circle is round, but a ball is a sphere. The Earth is alomost a perfect sphere. But is its slightly flatten at the poles and slightly bulges at the equator. The term for this is an oblate spheroid.
