Most Obscure Prius Facts (Way out there)
Discussion in 'Gen 2 Prius Main Forum' started by 200Volts, Nov 20, 2006.
  1. jiepsie
    jiepsie New Member
    267
    Jill doesn't understand you very well (that is, she does not understand ME very well) while reversing. Probably because of the reverse beeper.
  2. Tideland Prius
    16,556
    The right passenger footwell is smaller than the driver's side passenger footwell.
  3. harper42
    harper42 Member
    226
    <div class='quotetop'>QUOTE(Sarge @ Nov 21 2006, 08:21 PM) [snapback]352859[/snapback]</div>
    Can someone describe "where" under the hood these terminals would be located. Thanks.
  4. Tideland Prius
    16,556
    driver's side "above" the headlights. Just yank that black cover off.
  5. nicoss
    nicoss New Member
    304
    Switching from “Consumption Screen†to “Energy Monitor Screen†causes the upper right hand “Outside Temperature†blurb to shift vertically by a few pixels. B)
  6. windstrings
    windstrings Certified Prius Breeder
    6,280
    378
    Central Texas
    I accidently hit the voice button and it asked me to make a command.. usually I just hit the button on the screen to cancel.
    I didnt' know you could just hold the button down and it would cancel.
  7. Tideland Prius
    16,556
    On the 2004 models, when you spray the washer fluid for the rear wiper, it automatically wipes as well (like the front wipers).
    On 2005+ models, when you spray, it doesn't wipe automatically.
  8. Tom_06
    Tom_06 Active Member
    609
    142
    Newark, Delaware, USA
    <div class='quotetop'>QUOTE(Tideland Prius @ Dec 23 2006, 01:03 AM) [snapback]365936[/snapback]</div>
    My USA 2006 model must be defective, it acts like your 2004. I'll have to check Barb's 2005.
    - Tom
  9. Stev0
    7,201
    1,074
    Northampton, MA
    2022 Prius Prime
    If I remember correctly, my 2006 wipes the rear automatically when you squirt. Oh, dear, that just sounds so wrong.
  10. kDB
    kDB New Member
    241
    Fenton, MO
    I haven't checked mine for sure, but it might be how long you hold it. I'm pretty sure my 2005 can squirt on the front window without the wipers moving. It's how I remove a little frost on the window. Squirt, wait, squirt, wait, wipe.
  11. dmckinstry
    dmckinstry New Member
    1,034
    Cheney, WA (Near Spokane)
    <div class='quotetop'>QUOTE(kDB @ Dec 23 2006, 07:49 AM) [snapback]366000[/snapback]</div>
    And I just checked my rear wiper. Only doing the squirt does a swipe of the blade. This is on an '05 delivered on August 15. 2005.
    Dave M.
  12. Tideland Prius
    16,556
    <div class='quotetop'>QUOTE(Tom_06 @ Dec 23 2006, 05:39 AM) [snapback]365971[/snapback]</div>
    hmm... did I get mixed up? (i.e. 2005+ auto wipes and 2004 doesn't?)
    oye.. gotta double check next time before I post.
  13. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    i do not know... i had both and the both auto wipe. in fact, i used to play with mine because if you squirt small enough (this topic is getting a bit weird!!) the wiper will not engage. so i used to see how many times i could squirt without a wipe..
  14. windstrings
    6,280
    378
    Central Texas
    <div class='quotetop'>QUOTE(DaveinOlyWA @ Dec 23 2006, 08:56 PM) [snapback]366155[/snapback]</div>
    Does yours wipe before or after it squirts? :lol: :lol: :lol:
    And does it only squirt if you play with it???
    I was told it may be best not to play with it.... :blink:
  15. hill
    8,804
    <div class='quotetop'>QUOTE(chogan @ Nov 21 2006, 09:29 AM) [snapback]352448[/snapback]</div>
    Sorry, but owning the RX-400h (besides the '04 prius) ~ we have to take exception to that there factoid.
    Equally not factored is how much mileage the Prius LOOSES when 3 or 4 big fatso's get in. In fact, you don't even have to be FAT to overload the Prius (my 2nd fact for the thread .... drum-roll ... ) . At 6'"-5" and 220-225lbs (then maybe another 5-7lbs of clothing), some might call me on the 'light' side. But even though FOUR similarly sized folks could easily fit in the Prius, it would be over it's max weight limits !!
    What's up with that?
  16. roadwarrior
    roadwarrior New Member
  17. PA
    PA Member
    427
    27
    Raleigh, NC
    2019 Prius
    <div class='quotetop'>QUOTE(hill @ Dec 25 2006, 02:32 PM) [snapback]366521[/snapback]</div>
    So that's why Japanese Prius mileage is higher than that of the U.S. Prius! :)
  18. Tideland Prius
    16,556
    <div class='quotetop'>QUOTE(guppy @ Dec 25 2006, 03:04 PM) [snapback]366563[/snapback]</div>
    Do a search on EV mods, EV switch and so forth. You'll find all the information you need.
  19. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    the weight limit is a problem as during both playoff games last year, we were overloaded as well, (had one passenger who was 320 lbs) but my already overinflated tires and BT plate helped to handle the extra weight. i didnt think to track my mileage because, due to logistics and work schedules, both trips were made at 70+ mph, so several factors created a loss of mileage. but despite 100+ miles in those conditions, my overage tank mileage was still in the normal range.
  20. windstrings
    6,280
    378
    Central Texas
    <div class='quotetop'>QUOTE(PA @ Dec 25 2006, 05:13 PM) [snapback]366565[/snapback]</div>
    I'm guessing its because they don't have the long straight roads we do where you can cruise 80 - 90.. or prob even 70 for that matter very often.. so thier speeds are much more modest.
    I don't know what the temperatures are like there, but thats a biggy for mileage too.
    The EV switch is more of a fun toy... if you really work at it, the return is little or modest at best.... not a reason in itself for improved gas mileage of any noticable difference.
