Most Obscure Prius Facts (Way out there)
Discussion in 'Gen 2 Prius Main Forum' started by 200Volts, Nov 20, 2006.
  1. Bill Merchant
    Bill Merchant absit invidia
    4,096
    87
    On a 2007, you can choose QWERTY keyboard layout for the nav system, but if you register names and numbers for the phone system, the keyboard layout is ABCDEF.
  2. paula_g
    paula_g New Member
    In any of the Secret Menus is there one for language? I remember seeing a language screen mentioned somewhere and now I can't find it. I have a Japanese import and would love to change it to English.
    This is a brilliant thread.
  3. Dan.
    Dan. MPG Centurion
    387
    127
    Houston, Texas
    Disclaimer: Not speaking from spec, just kinda dead reconing, so it may be off base a bit.
    If you listen for it (roll up windows and turn off radio and AC), when you hit POWER to shutdown the car, you will hear a loud CLICK-CLICK coming from near the trunk. I've decided (no proof) that these are the high volt relays being thrown open.
    The relays default to open. I imagine this like a spring loaded switch where the spring is held down by some electric clamp that is engaged when the car comes online. So in my imagination, when the power is cut and the car goes offline, the now unpowered clamp releases and the springs throw the relays up to their at rest position (open).
    So for the non-technical, this keeps the highvolt battery disconnected when it's powered off. Making it safe for anyone who might need to saw the car in half. From what I've read the relays are blown open if the inertia sensors figure out that you've wrecked the car and deployed airbags. again, so it's safe to saw the car in half (presumably to pull you out).
    I'm sure the real system has more to it than that, but this is a simple way for me to visualize, and explain it.
    11011011
  4. Tideland Prius
    16,559
    <div class='quotetop'>QUOTE(Dan. @ May 14 2007, 08:05 AM) [snapback]441631[/snapback]</div>
    Fold down the rear seats and the sound becomes really loud.
  5. priusincc
    priusincc Member
    332
    16
    NV
    I just discovered more-
    1.The lights for the sunvisor mirrors only come on when the sunvisor is straight up and down. It goes off up (of course) and goes off again when you push it forward. It wouldn't make sense to operate any other way.
    2. If you in "B" Brake mode, you can't engage the cruise control.
  6. silver-machine
    silver-machine New Member
    51
    Sheffield UK
    If you go into EV mode and then reverse then the backup camera works
    but
    if you select reverse and then EV mode you get the energy monitor and no camera
  7. slair
    slair Ubër Senior Member
    404
    Lafayette, IN
    Why would you want EV durring reverse anyway? The ICE transmission isnt designed to go into reverse, thats why its always electric durring reverse. Reverse is an automatic EV :p
  8. silver-machine
    51
    Sheffield UK
    -----Why would you want EV durring reverse anyway? The ICE transmission isnt designed to go into reverse, thats why its always electric durring reverse. Reverse is an automatic EV
    Well, I find that the ICE often starts/carries on running when you engage reverse. Whether the transmission in reverse is electric only I dont know, but is a bit beside the point.
    I use EV mode when backing out of my garage, and usually when swapping cars around - I think its nice being quiet for the neighbours.
    The quirk Im pointing out is that the sequence affects the operation, engaging EV before reverse doesnt stop the camera, but engaging EV after reverse does.
  9. exerfreak
    exerfreak New Member
    <div class='quotetop'>QUOTE(rposton @ Mar 17 2007, 07:37 AM) [snapback]407358[/snapback]</div>
    To shave, of course!!
  10. jiepsie
    jiepsie New Member
    267
    <div class='quotetop'>QUOTE(Slair @ May 17 2007, 08:39 PM) [snapback]444325[/snapback]</div>
    To prevent the ICE from pushing you forward, when you want to be going backward. The ICE is always connected to the wheels via the PSD (power split device or "transmission") and always pushes the car forward. You can see this when you start the car in "P", (no emergency brake), it will move forward a little when the ICE starts.
    If you reverse with the ICE running, the electric motor has to fight the forward force of the ICE. With the ICE off, it's easier for the electric motor to move the car and you waste a little less fuel. It's also easier to back up a hill this way I've heard, with the ICE running you may not be able to reverse up a steep hill.
  11. priusincc
    priusincc Member
    332
    16
    NV
    I had an interesting thing happen today; a first for me anyway. (Somebody may have posted it, but I didn't go thru all 21 pages of thread.) I was coming down a long grade (2500 ft drop) and the consumption screen indicated all "turtles" and no green mph graph.
  12. whitespider
    whitespider Member
    101
    Lansing, FL
    <div class='quotetop'>QUOTE(darelldd @ Nov 21 2006, 07:10 PM) [snapback]352764[/snapback]</div>
    What can you tell me about this? This is interesting as I'd like to add the audio/video capabilitys to my touch screens to play DvDs and such when i'm bored in any situation where i'm parked and such. :]
  13. SSmith
    SSmith Junior Member
    I do not know if this has been mentioned yet...
    <div class='quotetop'>QUOTE(tmorrowus @ Jan 27 2007, 07:32 PM) [snapback]381788[/snapback]</div>
    I leave my headlights on all of the time letting them shut off when open the drivers door. Today when I arrived at my destination a short downpour had just begun. While waiting out the rain I shut off the headlights to conserve battery. Once the rain let up I turned the lights back on in and went into the building. I happened to look back after I had gotten in and noticed that the lights were still on. I tested this later when it was not raining and had the same results.
    If the headlights are turned off and then back on when the car it not running and the drivers door has yet to be opened, they will not shut off automatically.
  14. Pinto Girl
    Pinto Girl New Member
    3,093
    350
    Push the power button twice without pressing the brake pedal, then release the parking brake...
    ...the red 'brake' indicator on the dash *stays on*!!
  15. Enoyls
    Enoyls New Member
    48
    <div class='quotetop'>QUOTE(Stev0 @ Nov 20 2006, 09:54 PM) [snapback]352358[/snapback]</div>
    :lol: I discovered this just the other day after having my Prius for a week. I thought I had poked around everywhere until I found that. ;)
  16. mktbob55
    mktbob55 New Member
    <div class='quotetop'>QUOTE(Warwind @ Nov 20 2006, 06:52 PM) [snapback]352357[/snapback]</div>
    Thanks...DUH! :lol:
    <div class='quotetop'>QUOTE(VABeachPrius @ Nov 20 2006, 08:31 PM) [snapback]352393[/snapback]</div>
    Can you share which Dash, BU Sensor and BU camera kits you installed and what year Prius???
    Thanks
  17. hb06
    hb06 Member
    550
    Huntington Beach, CA
    Under 12 mph, you can drive or glide into your parking space after unlatching seatbelts with no seatbelt beep for either driver or passenger.
  18. Larry_R
    Larry_R Wryter
    94
    Naples, FL
    <div class='quotetop'>QUOTE(GeronimoPFudgemuffin @ Dec 1 2006, 05:19 PM) [snapback]356388[/snapback]</div>
    It is a well-known fact that listening to Bruckner symphonies whilst washing the Prius may lead to permanent mind-warp, especially if is one of Anton's later ventures. Stay with Mozart or Haydn whilst sudsing your vehicle. Both of you will have a calmer demeanor as a result.
  19. DieselConvert
    DieselConvert Member
    121
    Central Coast, CA
    <div class='quotetop'>QUOTE(DieselConvert @ Dec 16 2006, 11:42 PM) [snapback]363328[/snapback]</div>
    Apology!! Looking more carefully at what I referred to as Prius sway bar connecting link is actually something else - probably a link for an attitude sensor for headlight vertical aiming to compensate for vehicle load weight.
  20. hill
    8,808
    Driving w/ the Map Display on the mfd, if you have icons displayed ... gas stations, Burger kings, what ever, and you're traveling w/ the car at the bottom of the screen, not w/ the display showing North at the top ... watch the icons, they'll turn with the car, so they'll always be facing upward :lol:
