Most Obscure Prius Facts (Way out there)
Discussion in 'Gen 2 Prius Main Forum' started by 200Volts, Nov 20, 2006.
  1. zenMachine
    zenMachine Just another Onionhead
    3,355
    300
    Not sure if this issue has been posted before, but I just noticed this yesterday:
    Absentmindedly I left my smartkey in the cup holder, powered the car off with headlights on, opened the driver's side door to get out and closed the door. The headlights stayed on. (Normally they go off as soon as you open the driver door.)
    Luckily I was in the garage and was able to notice that the headlights were still on, so I opened the door, grabbed the fob and took it out, closed the door and the lights went off.
    Is this the expected/correct behaviour of the SKS?
  2. Doc Willie
    1,717
    144
    Out there, somewhere
    Yes. For some reason the Toyota engineers thought this was better than a loud voice coming from the car "HEY A$$#0<3, YOU LEFT YOUR KEYS IN THE CAR !!!!"
    Personally, I appreciated that when I did it.
  3. davidtm
    davidtm Member
    180
    TJ'ville
    That's interesting, because whenever I power off with the headlights on, they always turn off as soon as I open my door. That means that the location of the fob is irrelevant. An '08 difference maybe?
    Anyhoo, I find that convenient when it's rainy - like the lights in my former Volvo.
    DM
  4. Clubford00
    Clubford00 New Member
    93
    Buffalo Grove, Ill.
    I dont know if this was mentioned or not, i wasnt going to read all 63 pages. When in cruise control if you go below 24 mph and then go back above it, you have to set your speed again for it disengages the set speed. All my other cars, as long as you dont shut the car off "Remember" the last set speed.
  5. jukeboy
    jukeboy New Member
    132
    SGV, SoCal
    I believe all Toyotas don't remember the set speed below a certain value; I remember seeing the numbers 25 and 40 somewhere...
  6. personallyuneek
    personallyuneek Yankee fan in New England
    47
    NorthEast
    The Car can be slowed to a stop using the brake pedal without having your rear brake lights come on.
    When Driving an 08 (at night) you can see the red brake light when you press the brakes hard enough. However if you gently press the brakes you can slow the car from over 60 to a stop and never have the brake lights come on
    I think it is because the engine is what is slowing the car down, but I don't really know. Just thought it was cool
  7. geodosch
    geodosch Member
    182
    27
    New Jersey, USA
    2013 Prius Plug-in
    It sounds as if your brake light switch is out of adjustment. It's true that the Prius will use the electric motors and/or mechanical brakes to slow and stop, but the brake lights should be on any time you are using the brakes. It may seem cool now, though probably not so much after you get rear-ended because your brake lights weren't on. :(
    inframan likes this.
  8. Rae Vynn
    Rae Vynn Artist In Residence
    6,038
    707
    Tumwater, WA USA
    Agreed. Get thee to the service center promptly! Your car has a defect!
  9. jammin012
    jammin012 The man behind The Man
    510
    Cali
    Just counted mine, all wheels have 5 spokes. When parked the upper 2 spokes on the right hand wheels are hard to see but they're there.
  10. moregas
    moregas New Member
    58
    Denver
    Reading this thead I learned a lot about the Prius. I am sure one of you will be able to tell me if there is a way to seek the radio channels from the steering wheel?
  11. Tideland Prius
    16,555
    Not that I know of. Only changing channels that have been stored.
    You can use the tune knob which is quite handy if you wish, instead of the SEEK button.
  12. JHSmith
    JHSmith 2020 Avalon Hybrid Owner
    184
    King George, VA
    Not sure if the Prius radio operates the same as my Camry's JBL system does, but with mine, if I HOLD the steering wheel's station selector UP/DOWN switches, the radio will search for the next station.
    Again, this is for a TCH, so YPMV (Your Prius May Vary).:rolleyes:
  13. moregas
    moregas New Member
    58
    Denver
    Holding the steering wheel's station selector UP/DOWN switches works. Now how about turning the "beep" sound off?
  14. Tideland Prius
    16,555
    D'oh! I forgot about that!! Thanks!
    Hmm, one of the menus have it. Perhaps the INFO menu has the BEEP OFF button?
  15. davidtm
    davidtm Member
    180
    TJ'ville
    I believe one can do this by pressing and holding the "^" or "down" button [sorry, no such symbol on my keyboard] until it beeps.
  16. Bear68
    Bear68 Member
    373
    72
    West Palm Beach, FLA
    Try leaving the car in "Ready"mode then reach in through the open window and power down and remove the fob. Don't open the door! Then hit the lock and the window up button. The car assumes you are still sitting in it.:eek:
  17. Bear68
    Bear68 Member
    373
    72
    I think they might have been planning for possible carjackers.... you hop out and let them have the car (Best advice in any case!!) then when they shut the car off...... it cannot be restarted!
  18. 200Volts
    200Volts Member
    439
    46
    Northern CA
    BEAR68,
    The windows will work for about 30 seconds after the power is shut down. Then they stop working.
  19. Bear68
    Bear68 Member
    373
    72
    Right. That's the normal sequence for most Toyotas. Certain systems remain powered for thirty seconds or until a door is opened, whichever comes first.
    The poster seemed to have been trying to find a way to lock the smartkey inside the car and leave it. Such as if you were dropping a car off for someone else who had a key but needed both keys avaiable. The procedure I outlined would allow that to be done.
  20. cala4era
    cala4era New Member
    Hamburg, Germany
    It took me some days to notice -- there is no ashtray anymore!
    I should have been alarmed by the fact that the power socket is now covered with a plastic lid instead of being plugged with a cigarette lighter.
    Nevertheless, since I am not smoking I feel this is a bold move. Actually, this is the first car I own that is not equipped for smokers! Some more points for a "greener" and healthier life style with a Prius :D
    "Thank you for driving a Prius"
    Data Daedalus likes this.
