Most Obscure Prius Facts (Way out there)
Discussion in 'Gen 2 Prius Main Forum' started by 200Volts, Nov 20, 2006.
  1. Tammy7287
    Tammy7287 Junior Member
    83
    Maple Valley, WA
    Thanks! I'll give it a shot. :)
  2. Tideland Prius
    16,558
    I doubt it. The TCH has a lock and it has SKS and it's a regular lock.
    Well... every car seat is higher than a Civic :D. (Seriously!)
  3. hschuck
    hschuck Member
    385
    bay city, ca
    How is this "regular lock" operated? I would guess it is electronic via radio link. There is nothing wrong with this. Also note that the parking brake (dash button) is commanded electronically and implemented mechanically via an electric motor driving a mechanical lock.
  4. mcfly2
    mcfly2 New Member
    48
    Austin, TX
    Right, assuming the TCH does have steering lock, and it's the same as the Prius with regard to the electronic push button start and the ECVT, then the lock must be electronically engaged and disengaged. Sorry, but I'm not driving in a car where an errant radio signal may lock up the steering.
    Data Daedalus likes this.
  5. bbald123
    bbald123 Thermodynamics Law Enforcement
    386
    275
    Harrisburg, PA
    Assuming. May. How about dealing in facts rather than fear. If you have a question about how a component works, you could always write Toyota and ask.
  6. mcfly2
    mcfly2 New Member
    48
    Austin, TX
    I don't care how the TCH works. Someone else brought that into the conversation. I'm just happy my Prius doesn't have an electronically controlled steering lock.
  7. Tideland Prius
    16,558
    I thought it did. I remember testing driving the TCH and going "hey.. my Prius doesn't have this!"
    not sure but it could be a prawl that locks into the rack & pinion gears to prevent it from moving.
  8. mcfly2
    mcfly2 New Member
    48
    Austin, TX
    No doubt this hypothetical steering lock would be mechanical. The question is how the lock is engaged and disengaged.
  9. Tideland Prius
    16,558
    ohh... then that'll be the job of the technical guys here or over at GreenHybrid haha.
  10. zenMachine
    zenMachine Just another Onionhead
    3,355
    300
    The distance between the posts for the front seat headrests is different from that of the back seat headrests. (Presumably to prevent you from swapping them - another ingenious Toyota safety feature?)
  11. chriscard25
    chriscard25 New Member
    35
    Chicago area
    The Volume and Tune knobs on the head unit can be pushed in to become flat with the surface.
    Chriscard25
  12. problemchild
    problemchild New Member
    429
    37
    OMG........... blasphemy.
    You shall burn in hell for stating such awful things here. Didnt you know the prius has been elevated to smugness and cant be bashed.
  13. patsparks
    10,664
    567
    Adelaide South Australia
    Prius has no steering lock. (may have been said already)
    When the radio knobs are pushed in you can still use them with your finger tips.
  14. blue2noise
    blue2noise Junior Member
    Long Island, NY
    George Bush has made it clear that the Prius doesn't actually exist.
  15. chrisspaulding
    chrisspaulding sexy, high tech, fun
    556
    24
    Kentucky
    That's cool. I didn't know that one.
  16. abq sfr
    abq sfr New Member
    690
    Albuquerque, NM
    But the GM Volt and hydrogen power cars do. I know, I saw him try to plug the high-voltage plug into the hydrogen filler port :eek:
  17. JustAnotherAsian
    JustAnotherAsian Junior Member
    ^true for most toyotas. tried it on four separate toyotas... :pound:
  18. bug67
    bug67 New Member
    Eagle River, AK
    I ran a search in this thread and didn't come up with any hits. I'm sure this has been mentioned elsewhere on the forum but anyhow...
    Here's what I found as odd and somewhat of an obscure fact. Here's a car that is supposed to be the epitome of economy. So, why is it I must purchase 3 different size windshield wipers when replacing them?:confused:
    Strange but true!:p
  19. Tideland Prius
    16,558
    The reason why the front wipers are different is because of two things (and it's not limited to the Prius, most new car designs are like that).
    - In an effort to be more aerodynamic, the windshield must be raked at a greater angle which will result in a larger windshield (and usually taller than it is wide) so to get the coverage, the driver's side wiper must be tall enough to reach near the top of the windshield when fully extended. Hence there leaves less space for the passenger side wiper (to the point where on some cars, they're angled)
    - To give the driver the greatest wipe coverage.
  20. penbed
    penbed New Member
    222
    USA-Arkansas
    - To give the driver the greatest wipe coverage.[/quote]
    That is exactly why I buy Charmin:rockon:
