Most Obscure Prius Facts (Way out there)
Discussion in 'Gen 2 Prius Main Forum' started by 200Volts, Nov 20, 2006.
  1. dogfriend
    7,512
    1,190
    Carmichael, CA
    Yep, I posted that one about 30 or 40 pages back.
  2. pdhenry
    pdhenry It's HEEERE!
    406
    PA
    Meanwhile, the speedo display isn't right in front of the driver, for some reason. It's definitely inboard of where I'd expect it.
  3. RtStuf
    RtStuf www.rtstuf.com
    39
    Prairie Village, Kansas
    After two months of delghted ownership of my '08 P I found I can turn the radio on/off by hitting the "mode" button on the steering wheel twice!
  4. Genoz World
    Genoz World ZEN-style living
    797
    22
    La Canada
    My advanced apologies if this has been posted before
    on the rear wiper, you can't lift it up because the motion has been limited.
    LIFT THE PLASTIC CAP AND cut off the plastic tab underneath. "CLIP" the plastic cap back on the pivot point and "voila!" you can now lift the rear wiper to clean the window.
    ******thanks MJ from the LA Prius club********
  5. warrior
    warrior New Member
    141
    Paso Robles, CA USA
    How much more storage space is added with the rear seats down?
  6. Yankees251
    Yankees251 Black Touring HI Package
    96
    Danbury, CT
    I think you meant press and hold the Mode for two seconds. That's how mine operates.
  7. peterbright
    peterbright New Member
    16
    Southwest Florida
    That drove me crazy until I figured it out.
  8. NC_Prius
    NC_Prius Member
    186
    Yeah, but I've always found it rude when some smokers flick their spent butts out onto other people's cars -- wondering why they can't just put them out in the ashtray provided and then empty it into the trash at their destination.
  9. Doc Willie
    1,717
    144
    Out there, somewhere
    Love thy neighbor as thyself.
    Trash yer body, trash everyone else.
  10. lenjack
    lenjack Active Member
    804
    114
    Pennsylvania USA
    If you have a desktop computer, the motherboard battery is the same as the two in the key fob.
  11. hill
    8,805
    Hugh? Our 2004 fobs only have one in the fob. On topic of the oldie 2004's ... somewhere along the line, you newer Prius owners no longer got cassette stereos.
  12. patsparks
    10,664
    567
    Adelaide South Australia
    No cassette in my 2004
  13. iluvmacs
    iluvmacs Member
    280
    104
    Madison, WI, USA
    That would definitely depend on the battery in the computer. Different motherboards use different types (though admittedly some are far more common than others).
  14. lenjack
    804
    114
    Pennsylvania USA
    I suppose you could be right on this, but every desktop made in recent years appears to have the same 2032 battery.
  15. zenMachine
    zenMachine Just another Onionhead
    3,355
    300
    The hatch door is not made of metal. You can't slap one of those magnet ribbons on it.
  16. dogfriend
    7,512
    1,190
    Carmichael, CA
    Aluminum is a metal. It just isn't ferromagnetic like steel is. The hatch (and hood) are made from Aluminum Alloy.
    Data Daedalus likes this.
  17. exproducer
    exproducer Junior Member
    Los Angeles CA
    To all:
    I have used this post to jump start my Prius Convertible. Little known fact is, most jumper cable clamps are too wide/large to clamp onto this piece, a small fitting that sticks up about maybe a 1/2 inch out of the inside of the fuse box. The jumper cable clamps that come on most portable battery charging units are too wide; oversized. The fuse box requires miniature fingers to pop the stays to flip open the fuse box to get to the post. It is located on the drivers side under the hood slightly forward. It has a slim brass flat band sticking up that you look for to know you have the right connector fastener inside the fuse box. One jumper cable goes to the small stem sticking up, one goes to ground on the body. Another factoid is, you will become very frustrated trying to get the clamp to hook on and stay put to jump start the Prius. It will cause you to stare aimlessly into space saying, this can't be. Needle nose type jumper clamps on a battery charging unit would make the exasperation level fall significantly.
  18. zenMachine
    3,355
    300
    Yes. I stand corrected :)
    Should've said steel, as the body is.
  19. BTSculptor
    BTSculptor New Member
    Arkansas
    I can - they both stay open in my car!
  20. Patrick Wong
    18,210
    6,510
    That design might facilitate LH and RH drive models. BTW, the Classic combination meter is centered.
