Motor oil article
Discussion in 'Gen 3 Prius Technical Discussion' started by bwilson4web, Oct 24, 2009.
  1. Fred_H
    Fred_H Misoversimplifier
    562
    488
    28
    Germany
    OK, I think I see the misunderstanding. When you wrote:
    I thought you meant that the oil has lower viscosity at lower temperature, and increases in viscosity with increasing temperature. So you meant that it has lower viscosity at lower temperature compared to a single grade summer oil, and increases to a higher viscosity compared to a single grade SAE xW oil with increasing temperature?
    If so, sorry for presuming that you didn't mean that, when it wasn't completely clear what you meant.
    #41 Fred_H, Nov 2, 2022
  2. ASRDogman
    ASRDogman Senior Member
    8,065
    4,086
  3. Taxi/Limo
    Taxi/Limo Active Member
    526
    107
    Even 0w-20 synthetic ?
    So then is it possible to avoid wear at startup?
  4. CR94
    CR94 Senior Member
    2,829
    1,242
    Northwestern S.C.
    What makes you think that's a problem? If it were, every Prius engine would be very short-lived.
  5. Mendel Leisk
    42,343
    Block heater usage before cold starts might help. With an oil pan heater maybe more.
    TGrracie and Grit like this.
  6. Taxi/Limo
    526
    107
    Seems like a good idea especially in cold climates if in fact there is wear upon startup which makes sense if there is .
    Just wondering
    Does the type of gas you use increase or decrease wear upon startup?
    Thanks
    #46 Taxi/Limo, Nov 3, 2022
  7. Mendel Leisk
    42,343
    I don’t think so.
  8. Fred_H
    562
    488
    28
    Germany
