Motor Oil question
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Taxi/Limo, Oct 28, 2022.
  1. Taxi/Limo
    Taxi/Limo Active Member
    526
    107
    I read an article about Motor Oil and it said what you should use depends on the age of the engine, your climate , your driving habits etc.
    What is the best choice for a gen 3 engine at about 84k miles slow acceleration driving at or under the speed limit in California whick gets very hot in summer but not very cold during winter.?
  2. Tombukt2
    Tombukt2 Senior Member
    13,765
    2,491
    Durham NC
    The 020 covers you pretty good for that weather it's very similar to what we have here in North Carolina I don't think you're going to do much better than that if it gets extremely hot you could go up to the maybe the 30 during the summer but probably no need.
    Taxi/Limo likes this.
  3. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    Mobil 1 EP High Mileage, weight as designated in owners manual.
    REVVL V+ 5G ?
  4. Grit
    Grit Senior Member
    6,577
    4,230
    Wilkes Land
    Stay away from high mileage up until your leaking from seals.
    TGrracie, RRxing and Mendel Leisk like this.
  5. Mendel Leisk
    42,194
    Yup, high mileage oils are kinda like methadone maintenance: once on it there’s no going back. They swell seals, should only be used if you have runaway oil consumption.
    Oil pick: any decent quality 0W20. I’ve been using Toyota up to now, but price just went through the roof, so switched to Costco’s Kirkland stuff. Seems ok
  6. Grit
    Grit Senior Member
    6,577
    4,230
    Wilkes Land
    If your in Arizona and closer to the equator, go w/ 5w 30. In SF, 0w20 or 5w20. SF is not like North Carolina, we don’t start engines below 40 degrees in the coldest winter.
    TGrracie and Tombukt2 like this.
  7. Taxi/Limo
    526
    107
    Okay
    What's the difference btwn 0-30 and 5-30? Thanks
  8. Tombukt2
    13,765
    2,491
    Durham NC
    I meant on the heat side of things y'all are starting to write regularly see our heat temperatures I'm well aware you don't see our cold to me super hot is super hard on super lightweight oils so if you're in the hundreds of degrees you know like 105 right regular You're at the upper end of the range for 20 aren't you You're right up there in the very upper end of the range of heat for 20 white oil if I'm not mistaken or you used to be I haven't looked at the stuff in a long time now they have oil as thin as water that they say will working 110° weather kind of makes me nervous being on the upper end of the scale of the fluids capability in the first place but that's how they've engineered all this now they're running everything at the bleeding edge so there's no headroom same with your radiator temps one little thing happens and boom you're in 295° instantly but that's how they like things now so one little thing happens and you need $4,000 worth of repair That's not how this used to go
  9. Tombukt2
    13,765
    2,491
    Durham NC
    In Central North Carolina down in the 40s is pretty normal for our winter It gets colder than that but around the 40s is pretty much normal It might go down into the teens late at night but by the time most folks are getting up getting dressed and getting ready to head off to work it's above 36 heading to 40 and probably be 55 that day midday in January happens quite a bit when I first moved down here in '83 it was 75 at Christmas and I was installing air conditioning in my 74 Corolla SR5 no kidding
  10. CR94
    CR94 Senior Member
    2,798
    1,231
    Northwestern S.C.
    The proper designations are 0W-30 and 5W-30.
    By definition, 0W-anything doesn't become too thick to allow cranking an engine at -35°C (~-31°F).
    5W-anything doesn't become too thick to allow cranking an engine at -30°C (~-22°F), but does become too thick at -35°C.
    See SAE J300 viscosity specs for further detail on viscosity limits of engine oil grades.
    mikey_t, jzchen and Taxi/Limo like this.
  11. Taxi/Limo
    526
    107
    Okay
    And the 30?
  12. Grit
    Grit Senior Member
    6,577
    4,230
    Wilkes Land
    You should take your car to dealerships for oil changes if you’re not proficient with oil weight specs.
  13. CR94
    CR94 Senior Member
    2,798
    1,231
    Northwestern S.C.
    Means the oil falls within a certain viscosity range at a temperature of 100°C and stays above a specified viscosity under conditions of the High Temperature, High Shear rate test. See a chart of SAE J300 for further detail.
  14. Taxi/Limo
    526
    107
    That's not going to happen
  15. rjparker
    rjparker Tu Humilde Sirviente
    10,883
    6,832
    Texas Hill Country
    There is one answer, 0w20. If you can't get it, use 5w20 and replace it soon with the right oil.
    and
    #15 rjparker, Nov 3, 2022
  16. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    Per literature kindly posted by @rjparker, Toyota agrees:
    0W-20 is best for fuel economy and cold starting ability.
    Something higher than 20 may be beneficial (in the second spec #).
    So one should alternate between 0W-20 every 10k mi/1 yr, and 0W-(your choice), but change at 5k mi/6 mo intervals? (This is the literal translation of that manual page)
    iPhone ?
  17. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    This recommendation from Toyota never made any sense to me.
    There is NO one "right" oil.
    The difference between 0W and 5W is so tiny that I suggest you would not be able to tell any difference, even after more than 100K miles
    of continuously using the "wrong" oil.
  18. RRxing
    RRxing Senior Member
    2,559
    1,835
    NEPA
    My 2022 Venza uses 0W-16 oil and has the same precaution if using 0W-20...
  19. Mendel Leisk
    42,194
    Could be Toyota's just doing cut-and-paste with various oil weights, and change intervals? I find it hard to take this too serious.
    CR94 likes this.
  20. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    This is a pretty new, high mileage oil test:
    (I haven’t finished watching yet)…
