Motor Oil question
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Taxi/Limo, Oct 28, 2022.
  1. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Hopefully more will chime in w/non-Toyota vehicles to help extra curricular reading & narrow down the exact oil for the 3rd gen Prius.
    #21 Grit, Dec 4, 2022
  2. RRxing
    RRxing Senior Member
    2,563
    1,842
    NEPA
    My general philosophy is to halve the recommended oil change interval and use the proper viscosity OEM oil and OEM filter. Looking for the cheapest oil/filter/whatever is too much work for so little return. I just want to keep my engine happy.
  3. CR94
    CR94 Senior Member
    2,829
    1,242
    Northwestern S.C.
    That's right. They're required to put in those silly statements in the US (and Canada?) manuals, even though oil of other viscosity designations (within reason) would function equally well and equally long, aside from slightly higher fuel consumption under some conditions. Look at manuals for the same engine in other countries.
    jzchen and Mendel Leisk like this.
  4. Paladain55
    Paladain55 Active Member
    414
    172
    The South
    There's not a huge difference between even 0w-20 and 0w-40 or even 5w-30. Use whatever. I like 0w-20 it is my favorite.
  5. CR94
    CR94 Senior Member
    2,829
    1,242
    Northwestern S.C.
    True. Specifically, the minimum required viscosity under High Temperature, High Shear-rate conditions is only about 11.5% higher for xW-30 oils than for xW-20 oils.
  6. Paladain55
    414
    172
    The South
    it's very surprising. it got me as well when i looked at the graph with them all and saw how little viscosity difference there was over the range of temps lol
