Motor resonate noise during idling or low speed running
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Ken_Prius4, Dec 7, 2016.
  1. Ken_Prius4
    Ken_Prius4 Junior Member
    Unknown
    I got my car (Prius 2016) 5 months ago. Recently I noticed resonate noise during idling or low speed running.Usually in the cab, this resonate noise is like from sub woofer which is quite unpleasant. But after I start moving the car, the sound almost disappear or change to very light. Anyone had the same problem? or any ideas?
    #1 Ken_Prius4, Dec 7, 2016
  2. Gen 2 Tom
    Gen 2 Tom Active Member
    333
    286
    Lincoln Park NJ
    I believe I hear the same vibration, low speed and cold engine, Almost sounds like a heat shield. But it comes and goes. I'm not to concerned, it can not be found until it gets worse.
    Al9003 likes this.
  3. Ken_Prius4
    Unknown
    Thanks, Tom.
    48,999
    have yu folks ever owned a prius before?
  5. Gen 2 Tom
    333
    286
    Lincoln Park NJ
    Yep, 200K of Prius experience / anomalies identification
  6. Ken_Prius4
    Unknown
    For me, just half year.
    I meant during idling, the engineer sometimes running and make sound, but the resonate noise is louder (now winter) than when I had this car at the beginning(summer).
  7. bisco
    48,999
    it runs at higher rpm's for warmup during colder weather. hard to diagnose on the net, you'd have to make a clear recording, or try test driving another. these engines are noisy by nature.
    RCO likes this.
  8. Pokey13
    Pokey13 New Member
    Oregon
    Does it sound like my car does?
  9. Tande
    Tande Active Member
    498
    301
    Mich.
    Certainly not normal.......mine doesn't do that.....
  10. kithmo
    kithmo Couch Potato
    2,404
    2,773
    47
    South Yorkshire, UK
    There is a small amount of "rougher" running during one of the warm up phases IIRC, but not like the video above, that is certainly not normal, I would be at the dealers with that one.
  11. mjoo
    mjoo Senior Member
    1,107
    1,311
    Michigan
    My wife had the same problem on her 2016 when she backed into a rock. This was a month after buying it new. What happened was the tailpipe got pushed back and caught the plastic underbody. The middle of the exhaust system shifted to one side and compressed like a spring. With the exhaust pushed up against the heat shield the engine vibration transmitted to inside the car. $tealer mechanic wanted $2800 until I looked at it on their lift. Fix took a minute and was free: with a crowbar push the tailpipe back and down to release it from the plastic.
    Pixel XL ?
