motor running no indicators on screen
Discussion in 'Gen 2 Prius Technical Discussion' started by allballgames, Sep 6, 2011.
  1. qbee42
    qbee42 My other car is a boat
    18,058
    3,082
    Northern Michigan
    Epoch, you have a lot of good information in that post, but your format makes it hard to read. A few paragraphs and a little more explanation would do wonders for clarity.
    I could follow your post, but I already knew the information. I suspect the people that really need it will have a hard time with it.
    Tom
  2. Britprius
    Britprius Senior Member
    5,194
    1,924
    Herefordshire England
    Thought it would be a good idea to fit a brake switch on the parking brake pedal in parallel with the one on the foot brake (assuming normally open contacts) so when stationary with the car in D and the parking brake applied the electric motors would not try to move the car, but have noticed on the UK Prius the stop lights work even when the car has no fob inserted. Is there one or two switches fitted on the brake pedal?
  3. qbee42
    18,058
    3,082
    Northern Michigan
    One switch, dual pole if you have cruise control.
    Tom
