Motor shakes when it first starts up or takes off
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by AJRoss57, Nov 9, 2012.
  1. Braddles.au
    Braddles.au DEFAnitely using an EBH
    295
    99
    Canberra, Australia
    For the benefit of startled American readers, 98 RON in Australia is 93-94 AKI in the US. 98 AKI is 102 RON!
    91 RON/87 AKI is perfectly adequate for the Prius ZVW30. Other posts on PC show a clear mileage advantage to using 91 RON/87 AKI for the 30. I've used 91 RON for the past 20,000km with no issues. I twice had engine knocking for a few seconds but only at ambient temperatures of about 0°c before I fitted an engine pre-heater.
    I'm not sure what petrol the Prius C needs.
    Part of the reason that 98 RON was more popular than 91 and 95 in Australia was that it had low sulphur and was therefore kinder to European vehicles that otherwise liked 95 RON/90-91 AKI. My Citroën only required 95 RON, but needed a tank of 98 RON every 3 or 4 tanks to avoid issues.
    Testing grades of fuel depends on the car chosen for the test. A high-revving engine that has the tuning to cope will generally benefit more from 98 RON. Put high octane into a standard engine and the difference in price simply will not be worth it. The way I drive my Prius 30 I don't need high octane. If I revved its ring out, then maybe I would... but then why would I be driving it.
    If you want to use 98 RON for the cleaning benefits, use it every 3 or 4 tanks.
  2. windstrings
    windstrings Certified Prius Breeder
    6,280
    378
    Central Texas
    What is the android software you're using to view those codes?
    How are you hooking up?
    Alan.. Sent with Tapatalk 2
  3. ramirezpn
    ramirezpn New Member
    Bay Area, CA
    Had the same problem with my 2012 C, yesterday (currently at 20k). Mine occurred in hot temperatures (meaning of course I had the AC blowing) after driving about 1.5 miles. I was stopped at a light and when I released the brake and gave it some gas, the CEL turned on and the car began to shake. I took it to the Toyota repair shop and when they started it, the engine light didn't even turn on. They'll do a diagnostic, per warranty, but I'm still waiting on what they'll find.
  4. ztanos
    ztanos All-around Geek!
    3,339
    1,150
    40
    Cumming, Georgia
    didn't watch the video, but Torque is free on Android and you can connect with an el cheapo $15 OBD 2 bluetooth adapter.
    minkus likes this.
  5. Drdiesel
    Drdiesel Active Member
    585
    152
    Monterey CA
    It sounds like the problem is ignition related. If the CEL came on, the dealer should have checked for stored DTC's
    and freeze frame data. That will tell them what the ECM is seeing. I would bet, it's a P03xx code.
  6. mahout
    mahout Active Member
    655
    116
    NC
    I like this. Additionally, you should check the motor mount bolts to be sure they are snugged up when the bushings are cold. You can do that yourself. Consult a service manual for the correct torque on the bolts. And the bushing can be defective too.
    PS its not a motor mount, its an engine mount. Engines are internal combustion; motors are electric or pneumatic powered.
  7. windstrings
    6,280
    378
    Central Texas
    Which one for for prius?
    I've seen camry etc but no prius.
    Sounds like the cheap ones are slow, dropout, and are unreliable.
    Alan.. Sent with Galaxy S4
  8. ztanos
    3,339
    1,150
    40
    Cumming, Georgia
    I paid $7 for mine... it's a universal OBD2 bluetooth adapter found on the googles... I don't have any issue with it on the Prius. Used it on my Saturn for 2 years before the PC. So far the only car it wouldn't find an interface for was FORD. Both an F150 and a Mustang refused to talk. But I can confirm this works on the PC.
    minkus likes this.
  9. ztanos
    3,339
    1,150
    40
    Cumming, Georgia
  10. windstrings
    6,280
    378
    Central Texas
    Too cool, Thx for the link, just ordered!
  11. Image Group
    Image Group Bounding Overwatch to Grandmothers house we go!
    73
    San Diego CA
    Took Nigel in today after what sounded like a rabbit caught up in the fan and got tossed around. Dealer is keeping him overnight. I'll let everyone know tomorrow. Prius 2013 C 20k miles
  12. windstrings
    6,280
    378
    Central Texas
    Prob just a cat! :confused:
    _____________________________________
    Alan............. Huh?..... What hump?
  13. mahout
    655
    116
    NC
    I'd still check that mounts are indeed tight and not fractured from the chassis.
    If thats it it will get worse.
  14. RTW
    RTW Junior Member
    31
    Portland Oregon USA
    I'm curious what happened at the dealer? Any resolution? (The almost literal thing happened to ours last night, though it could have been a large squirrel...;)
  15. Flying White Dutchman
    4,376
    313
    my eye just came across this topic
    i was thinkng maybe i am the only one
    but i have also some shaking just for 2 or 3 seconds at cold start
    my P2 did not do this with the same 1.5 liter ice.
    you can really feel the steering wheel shake at that point it then levels off and fades away.
    i was thinking maybe the prius was bigger and you do not notice it but i still think its strange.
    you can heat it a little at this video
    the first 2 seconds of the ice start.
    those few seconds it sound like its hitting something and then it go's away
    or is this normal? any other people made a ice start video of the prius c?yaris hsd?
    00:45- 00:48 you can hear it knocking.
    Prius C / Yaris hybrid engine start - YouTube
    temp is in celius around 10c
  16. GeoZoo
    GeoZoo Junior Member
    40
    17
    My new PriC3 shudders when it's chilly outside first thing in the morning. Then once it gets warmed up it seems fine. But it freaked me out at first. Never had a car "shiver" :p
  17. Flying White Dutchman
    4,376
    313
    brbrbrbrbrbrbrb its cold ;-)
  18. Okinawa
    Okinawa Senior Member
    1,333
    320
    I have a 2011 Prius. About 2 times since I have had the car, when I started it in the morning I had a knocking sound. I put a can of Chevron Techron in the gas tank and never had it again. I put Chevron Techron in my tank about every 6 months. It makes my car run better and no more knocking. Give it a try. It won't hurt a thing.
  19. bmw
    bmw New Member
    langhorne pa
    Im having the same issue with my 2012 prius c with 25k miles on it...
    see my post... below
    2012 prius c low speed & cold start vibration... | PriusChat
  20. infinitewindow
    infinitewindow New Member
    Los Angeles
    This happened to me today with my Gen3 2011 Prius Two... except the weather was 76F/24C. When the gasoline engine came online, a fast rhythmic whuff-whuff-whuff-whuff noise came from the front of the car, and I could feel the car shake in time with the whuff. I turned off the car, let it rest for ten seconds, and started again, and it went away.
