Motor Sound When Brake is Depressed
Discussion in 'Prime Main Forum (2017-2022)' started by Cocular, Apr 6, 2019.
  1. Cocular
    Cocular Junior Member
    2019 Prius Prime
    I just bought my new prius prime plus 2019 yesterday. Today I find that there is a weird motor sound when the brake pad is depressed before I touch the start button. This sound lasts for about 2 seconds. Is this normal? From Whirling sound at start-up | PriusChat, some people say this noise is from the brake booster pump. Not sure if this is my case.
    52,810
    correct, electric pump motor, no worries.
    prius makes lots of funny sounds you are not used to, both running and parked. you'll get accustomed.
  3. Cocular
    2019 Prius Prime
    I am a little worried about this because I did not hear it yesterday when I do the test drive. So does that mean every Prius Prime has the electric pump motor sound before startup?
  4. jerrymildred
    jerrymildred Senior Member
    11,517
    14,167
    Tampa, FL
    I'm quite sure that's your case. I'd be very concerned if it didn't make that noise. No hydraulic pressure would be bad. Remember, your car has no belts whatsoever. Brakes, steering, air conditioner, coolant pumps, all driven by electric motors so they are available when the gas engine (ICE) is not running.
  5. jerrymildred
    11,517
    14,167
    Tampa, FL
    Every Prius has it, not just Prime. It doesn't pump all the time. Only when the pressure switch tells it to pump. If you open the door and the car happens to have sufficient pressure, there's no reason for it to pump.
  6. bisco
    52,810
    it's easy to be distracted by sales weasels during test drives, along with all there is to take in with a completely new car.
    there should be a section in your o/m regarding sounds.
  7. jerrymildred
    11,517
    14,167
    Tampa, FL
    Page 88 in my manual. Note: "Engine" and "Motor" are not equivalent. ;)
  8. Montgomery
    Montgomery Senior Member
    2,254
    2,242
    Orange County, CA
    Your Prius will make different sounds. Even sometimes 10 minutes after you have parked. No worries. Welcome to Hybrid country!
  9. Cocular
    2019 Prius Prime
    Thanks for all the answers! I think I just need to get used to the electronic pump sound! Last question, how frequently does your brake pump start? Today I drove my car for about 10 miles in EV mode and I found the electronic pump would start every other time after I heavily depressed the brake. Does that frequency sound right to you?
  10. jerrymildred
    11,517
    14,167
    Tampa, FL
    Sounds fine. It will depend on how much you use your brakes. Keep in mind that heavy braking is the absolute best way to ruin your fuel or battery efficiency. It's worse than rapid acceleration.
  11. Montgomery
    2,254
    2,242
    Orange County, CA
    Cocular, it is common for the new Prius driver to experience a different driving experience from other cars. The Prius is really a computer. The Pruis is trained to react to the driver each time you drive, and its goal is to get you the best gas mileage each time you drive. So, if you brake more often one day, it will compensate, if you drive 100 miles on a straight highway another day, it will compensate. And sometime in the future, you are going to drive over a large bump, or a pot hole or a slick surface..............and when that happens, your car will beep, make a buzzing noise, and a yellow triangle will briefly flash on your dash. This is common also. Your traction system is simply modifying to the conditions. So, keep checking in here with us all! We have experienced the new, different life of owning a hybrid.
