Motorola Q bluetooth
Discussion in 'Gen 2 Prius Technical Discussion' started by longshortofit, Jul 28, 2006.
  1. Rangerdavid
    Rangerdavid Senior Member
    1,362
    52
    Boone, North Carolina
    Three Touring
    OK, I got my new black Motorola Q from Verizon 2 days ago. It pairs nicely with the Prius. I've started fumbling around with transfereing contacts and thus far can only get it to transfer one at a time. I need to get the dreaded "owners manuel" and actually read how to do this. supposedly the Q will transfer OEBX files so it should work with the 2006 Prius.
  2. clifford
    clifford Member
    156
    <div class='quotetop'>QUOTE(IsrAmeriPrius @ Jan 3 2007, 01:16 AM) [snapback]369905[/snapback]</div>
    Just to let you know. I recently bought at Verizon, lg vx8600 and have not had any problems with using it with the bluetooth or transfering the phone book. It works great although I have not figured out the voice commands yet. Good luck.
  3. Rangerdavid
    1,362
    52
    Three Touring
    <div class='quotetop'>QUOTE(IsrAmeriPrius @ Jan 3 2007, 12:16 AM) [snapback]369905[/snapback]</div>
    Correct you are sir!! However, according to Verizon, it does. Expecially the black Q with the firmware update that came out on 12-12-06. here's the link::
    http://support.vzw.com/pdf/BT_Car_Kit_Q.pdf
  4. DHonzik
    DHonzik Junior Member
    70
    Oak Creek, Wisconsin
    <div class='quotetop'>QUOTE(Platup @ Aug 3 2006, 11:14 AM) [snapback]297051[/snapback]</div>
    I have a Verizon V710 and could never get the above program to work, it just errors out with the following error
    Method "Full name" not supported by automation object
    I've tried all the other name methods and get the same error.
