Motorway mpg
Discussion in 'Gen 4 Prius Main Forum' started by Roo., Jan 18, 2018.
  1. Roo.
    Roo. New Member
    Uk
    Almost convinced myself to get a Prius but one thing holding me back is worries about fuel economy for my driving. The Prius will be used for my daily commute which is a 90 mile round trip, almost all on the motorway. Currently I drive a diesel i30 and manage around 60mpg (slightly lower at the moment due to cold weather). I test drove a Prius last week and got a reading of 63mpg on a motorway stretch - I was rather impressed! The car only had 50 miles on the clock so I was hoping after engine break in that may even improve. However almost everything I find online suggests I will be doing well to get 50-55mpg on the motorway in the Prius. What are your experiences? Was my test drive a total fluke?
    pilotgrrl likes this.
  2. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    I assume that's normal MPG (not USA galleons?).
    I did a longer run the other day - 275km return, but it was quite congested one direction, so a lot was slower, and I got 80(UK)MPG, using RADAR Cruise the whole way and back, and that included going through the city on the return.
    I do a 25km commute (plus return) 3 or 4 times a week, and get between 68 and 72(UK)MPG. But if I'm just puddling around my suburb with little short intervals between stops at various shops etc, it might get down below 60(UK)MPG.
    I had a FIESTA Diesel (Manual) before this - and it averaged 59.7(UK)MPG over 60,000km - and PRIUS is appreciably bigger.
    Prior to that, I had a FOCUS Diesel (2litre Manual) which averaged 52MPG over 60,000km. My commutes in all 3 cars are similar, and I guess my driving is too.
    My average over 25,000km is 68.2(UK)MPG in the PRIUS - with 15" rims.
  3. Roo.
    Roo. New Member
    Uk
    Now realising I've been quite daft without realising it. Did not realise there was a difference between US and UK mpg - doh! Most of what I've read has been US based, and having just done a quick Google I have now learned that 55(US)MPG = 66(UK)MPG which broadly fits with both my test drive experience and what you've described.
    Thank you!
  4. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Your cruising speed on the motorway will be crucial to the fuel consumption. Best economical speed is 50-55mph. Over that and it will impact on the mileage. I cruise the M5 at 70mph an get around 55-60mpg, but going faster than that and it falls off dramatically. I would say, you won't be disappointed if you keep it under 71mph.
  5. Roo.
    Roo. New Member
    Uk
    Sounds similar to my current diesel - thank you
  6. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Actually, it might be a bit quieter than the diesel, but your mileage does improve if you learn to lift your right foot whenever possible. You don't get the same engine braking in a Prius as strongly as you get now. I still use the heavy boot occasionally for fun, but it only pulls the mpg down for a while and is not a major impact on fuel.
    Edit: Unless you do it all the time!
    #6 RCO, Jan 18, 2018
    jerrymildred and bisco like this.
  7. Prodigyplace
    12,699
    11,842
    Central Virginia
    A light touch on the brake uses regenerative braking to use the stopping energy to recharge the battery rather than converting to heat.
    A harder touch activates the normal friction brakes.
  8. bisco
    52,557
    it's all about speed, not which road you are on. it is possible that the prius won't be quite as good as a diesel, depending on the diesel.
    also, the prius gauge is optimistic, and you will find the calculation at the pump a bit disappointing.
  9. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    I was trying to differentiate between the ICE drag and the Prius drag on lifting off the accelerator, not involve regeneration.
    Prodigyplace likes this.
  10. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    A 240 mile round trip on mostly motorways last spring showed me 66 mpg on the trip. Cruise was set to 77 mph (to allow for the 10% built in speedo error), most of the way, with the exception of a couple of 50 mph road works with average speed cameras where I set it to 55 mph.
    As RCO says above the lower the cruising speed the better the mpg. I'm pretty sure if I had travelled the whole journey at 55 mph :sleep: I'd have seen well over 70 mpg on the trip (just before I fell asleep). I've done 90 mile journeys to the coast, wholly on A roads, keeping up with the traffic and speed limits and seen around 80 mpg on the trip.
    RCO likes this.
  11. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    You old enough to nap at the wheel??? :ROFLMAO:
    kithmo likes this.
  12. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    Yes, 65 in April, I find the Gen 4 is so easy and less stressful to drive that I have to prop my eyelids up with matchsticks so's I don't fall asleep at lower speeds (don't you just love adaptive cruise and LKA when you're asleep) :whistle::LOL::p
    jerrymildred, RCO and Prodigyplace like this.
  13. Prodigyplace
    12,699
    11,842
    Central Virginia
    Unfortunately, we do not have LKA (Lane Keep Assist). Toyota replaced it with the less capable LDA (Lane Departure Alert). I believe that may be true for you too. Some older Prius models had LKA.
    RCO and kithmo like this.
  14. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    My bad, LDA wakes me up enough though.;)
  15. Sam Spade
    Sam Spade Senior Member
    2,036
    1,024
    2017 Prius c
    THIS.
    And the MPG shown by the onboard computer usually isn't accurate; it usually err's a bit on the high side.
    kithmo and RCO like this.
  16. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    The accuracy, while potentially beneficial, it is not as useful as the variation in averages - however measured - so long as the measurement equipment is a constant.
    kithmo likes this.
  17. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    Mine seems to be consistently 5 mpg out on the trip compared to tank to tank calculated mpg.
  18. Prodigyplace
    12,699
    11,842
    Central Virginia
    The one tank I calculated, the car was about 10% high.
    #18 Prodigyplace, Jan 19, 2018
    kithmo likes this.
  19. Mendel Leisk
    42,061
    That's too kind. More like "invariably biased".
  20. alanclarkeau
    7,045
    7,593
    Yes, I think they all err on the optimistic side (KIA and FORD were similar) - it's a calculated figure from various inputs. Mine has varied between 4 and 8%.
