Mount carplay monitor
Discussion in 'Prime Main Forum (2017-2022)' started by mveras1972, Dec 10, 2022.
  1. mveras1972
    mveras1972 Member
    173
    63
    New Philachussetts
    I bought a CarPlay display and the perfect mounting spot for the 2017 Prius Prime is right above/behind the steering wheel as it does not block anything at all. Does not block the speedometer which is off-centered to the right, and I can still see the front hood and HUD display on the windshield in its entirety. The problem is, mounting a suction cup on the curved dashboard surface is nearly impossible because it is curved and has a coarse texture. I have a great suction cup with a gel that sticks to most surfaces, but the curve on the dashboard is too much to make it stable. The CarPlay display comes with a flat plate which you can use to help the suction cup stay in place, but then the curve prevents it from staying put. Is there any product out there that I can use to place it under the suction cup and help reduce the dashboard curve?
  2. schja01
    schja01 One of very few in Chicagoland
    1,746
    1,162
    Chicagoland
    2018 Prius
  3. MalachyNG
    MalachyNG Active Member
    300
    221
    Northern NY
    2022 Prius Prime
    A flat piece of plexiglass stuck to the dash with command strips so you don't rip up the plastic or leave residue if/when you trade in or sell.
  4. Trollbait
    11,560
