Mountains and Fuel Economy
Discussion in 'Gen 4 Prius Fuel Economy' started by axle2152, Aug 28, 2016.
  1. fuzzy1
    10,722
    I haven't seen a BSFC chart for your Gen4. But on the Gen3, any peak "sweet spot" is very small, the engine is tuned and operated quite close to maximum efficiency over a very wide RPM band.
    Gen2 has a bit more pronounced and narrow peak efficiency, but even its version is short in height and fairly broad in RPM compared to traditional non-hybrids.
  2. Vman455
    Vman455 Senior Member
    540
    556
    The Middle
    BSFC map for Gen 2 and Gen 3 compared:
    The 2ZR-FE in the Gen 3 has a larger and more efficient "sweet spot" than the Gen 2, like you said; I seem to remember from the press release that Toyota said the reason they went with a larger 1.8L engine was because the higher torque output let them run at lower RPMs for the same power but better efficiency at a given speed. I would imagine the Gen 4 is similar since it's basically the same engine.
    fuzzy1 likes this.
  3. Tideland Prius
    16,683
    Note that the peak torque in the Gen 4/Prime is much lower than previous iterations at 3,600rpm. Helps with lowering engine noise.
  4. fuzzy1
    10,722
    I'm portraying it as a very broad, nearly flat plateau, not a narrow peak. Almost any operating condition from a bit above idle speed, up to roughly 4000 RPM, counts as being in the "sweet spot". Pulse & Glide counts on finding and getting in to a sweet-spot peak that is not being used in normal cruise.
    I am presuming that Gen4 is a least as good as Gen3. I'm actually hoping for even better, but don't recall seeing anything showing it.
  5. aforkosh
    aforkosh Active Member
    413
    272
    Oakland, CA
    2023 Prius
    Between August 18 and August 23, I went on vacation from the San Francisco Bay Area (specifically Oakland, CA) to the Eastern Sierra of California. I've posted images of my dashboard stats when I returned here. The trip involved driving from Oakland over Echo Summit and Luther Pass to Minden, Nevada. The next day, I drove to Mammoth Lakes, CA. I spent two days based in Mammoth Lakes at about 8,000 ft above sea level. I then took two days August 22 and 23) returning to the bay. The first day, I summitted the Sierra at Tioga Pass (9,941') and ended the day in Groveland, CA (about 3,300 ft). I finished the return the following day. Overall mileage for the 656 miles traveled was 54.9 mpg.
