Mouse woes
Discussion in 'Gen 3 Prius Main Forum' started by jenkins1101, Apr 16, 2018.
  1. jenkins1101
    jenkins1101 Junior Member
    Had a mouse get in the car and it chewed up part of the back seat. Any idea cost wise to get this fixed?
  2. Mendel Leisk
    42,271
    That might be the tip of the iceberg too: they have a taste for wire insulation, have made nests in the cabin filter. Make sure you're well shut of it (them?) asap. Consider how it could have got in too.
  3. jenkins1101
    Thanks. I am pretty sure it came in through the filter area. I didn’t see a next but it chewed some plastic in that general area. So far no wire damage. Going to set some cameras and traps tonight.
  4. Mendel Leisk
    42,271
    In a garage, or outdoors?
  5. jenkins1101
    Garage. I got it on full survelience. It waited till it got dark then I saw it hop up to my wheel well. Set up another camera at the suspected entry point and snapped a pic. Where is it getting in to reach there? Can I access this point easily?
    Lightning Racer and RMB like this.
  6. KennyGS
    KennyGS Senior Member
    1,243
    1,046
    Keystone State
  7. Tande
    Tande Active Member
    551
    337
    Mich.
    Had same thing happen to our passenger side front seat.......was able to purchase the OEM cushion cover from an on/line Toyota dealer.......installed it myself........FWIW
  8. Mendel Leisk
    42,271
    That is a GOOD picture! :eek::ROFLMAO:
    It's getting in through the cabin air intake: watch @NutzAboutBolts on spark plug replacement, #13 here:
    Nutz About Bolts Prius Maintenance Videos | PriusChat
    It shows how to remove the wipers, wiper arms/motors and windshield cowl. You will need to put some screen over the intake, maybe with pop rivets. You can get 1/4" opening galvanized steel mesh at hardware stores; it's commonly used on residential vents, for just this purpose.
    I should do this too. I did but such mesh on the engine air intake snorkel.
    We had a small rat take up residence in engine bay, but luckily he didn't find his way into the cabin. Around the time we were discovering this guy, we also happened to take over ownership of a Shiba Inu, and he summarily chased the rat out, never to return. :)
    Robert Holt and NutzAboutBolts like this.
  9. jenkins1101
    Yep it’s actually a decent size rat. It laughed at my glue pads and called me a newb. Got a full sized cage trap so hopefully that does the trick tonight. I was hoping it would stay in the garage when I left for work this morning but it hitched a ride. Seems to really like the car for some reason. I stayed up all night trying to get the dang thing to leave. I had 2 cameras set up so if I saw him on the floor I can pull the car out but it ran back into the car every time I came to the garage.
  10. Mendel Leisk
    42,271
    You better take the plunge, get that cowl off, harden the entrance with a mesh. Any neighbor with a dog? That'll help flush it.
  11. Mendel Leisk
    42,271
    As to how the rat gets to that firewall vent opening, I'm not sure, but I suspect he's slipping behind the wheel well plastic, up near the top, maybe where the shock goes through, then up a bit further and over into the cavity below the wipers. In any event, a 1/4" mesh secured across the firewall opening will stop him, regardless of how he gets there.
  12. Mendel Leisk
    42,271
    Pulled off the cowl on ours today, and installed a 1/4" galvanized wire mesh. Some pics to come.
    The opening:
    Possible egress route:
    (Couple of possible mouse egress from wheel well there.)
    Screen installed:
    (Used a 1/8" drill bit mounted on a Dremel, centre punched locations in advance. Still not that easy. A hand operated pick/awl of some sort might be better for this: the steel is quite soft/thin. Locations maybe not optimum, but best I could do with limitted acess. The mesh is stiff material, seems secure with fasteners as located. The mesh I used was 11"x7" IIRC, but cut it generous, and then trim after a trial fit to make sure.)
    Screws I used:
    #12 Mendel Leisk, Apr 18, 2018
    Robert Holt and Raytheeagle like this.
  13. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,526
    Bay Area, California
    2019 Prius Prime
    What prompted the cowl removal today:whistle:.
    Or just another slow day at the office:ROFLMAO::ROFLMAO:.
  14. Mendel Leisk
    42,271
    Slow day. Sunny too.
    Raytheeagle likes this.
  15. Raytheeagle
    11,267
    15,526
    2019 Prius Prime
    Never got to see the sun today:(.
    Had to keep the wolves at bay:cool:.
  16. jenkins1101
    Thanks for the info. I was able to finally trap it. Will look into it’s entry point. Can anyone tell me if that little slot above the cabin filter where it accessed the cabin had something there? I found this thin black foam piece near it and I think it was over that slot. Here is a video of the culprit.
    GFO, Lightning Racer and StarCaller like this.
  17. Tande
    Tande Active Member
    551
    337
    Mich.
    Beautiful!! .......
  18. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    Speaking specifically about the damage pictured in the original post, my opinion is to have it 100% properly repaired, would mean upholstery work, and that can be incredibly expensive. I've known people that have taken community college course on the subject, just so they could do it themselves.
    My question then becomes, how much could you ignore? Some type of tastefully done patch? Sewing up the tears and throwing a pillow over the area? Seat covers?
    You could call around, it's been a few years since I've had to investigate auto re-upholstery, to have the work done well, it's not cheap. I might try to find a compromise I could live with, something between full repair and duct tape.
  19. jenkins1101
    I called a place and they quoted me $225. Not bad it was a very small spot which is completely covered when the seatbelt receptacle is in its proper place.
  20. The Electric Me
    9,083
    5,801
    For a complete re-upholstery? That sounds almost too reasonable.
