Mouse woes
Discussion in 'Gen 3 Prius Main Forum' started by jenkins1101, Apr 16, 2018.
  1. Tande
    Tande Active Member
    551
    337
    Mich.
    Click here for sample ......
  2. jenkins1101
    jenkins1101 Junior Member
    So, can anyone tell me how the air intake flap is supposed to be attached? I’m curious how it worked and if I need to bother with this. When I change the air to re circulate the top comes down. Was the purpose of this flap to move with it or was it always in the same spot covering those holes? If anyone has a video if it while switching between each mode that would help.
  3. prius8654
    prius8654 Junior Member
    That picture of the mesh screen on the duct tube, when I look at my 3rd gen, I see there is a plastic screen built into the cowl at the beginning of the air intake just below the windshield, and then when I look under the hood at that area, it looks like it is all covered up, how is a mouse getting in to that open port that you put a screen on if there is no visible direct access to that large black duct?
  4. prius8654
    You probably saw your answer by now, but that black mesh that you were holding in the photo goes just behind that opening that you can see in your pic. And it stays stationary.
  5. Mendel Leisk
    42,269
    I believe that’s the cabin air intake you’re asking about? It’s too damp and cold for me to check right now, but I believe there are some openings a mouse can get through. Likely IN the engine bay, and mice can easily get in there. They DO get in; quite a few reports here, owners finding nests atop the cabin air filter.
  6. prius8654
    Yes I'm talking about mice getting into the cabin air filter area, as most people seem to say that is the number one ingress point on the gen 3, yes?
    But I see that there is a plastic screen at the bottom of the windshield built into the cowl where the air is drawn in for cabin air.
    When the car is switched off It goes to recirculate mode and blocks off the entrance into the cabin at that cabin air point, so how does something get in if that cowl screen is intact?
  7. Mendel Leisk
    42,269
    Take it up with the meeces?
  8. prius8654
    Thanks
  9. bisco
    52,779
    recirc door will not restrict mice
  10. prius8654
    Ok. Mendel did mention a good video from nuts about bolts spark plug replacement, I guess when I have all that stuff out I will be able to see exactly where they might be coming in from, apparently this is a common issue on the 3rd gen.
    We have a second gen also and have never experienced this issue Also our Sienna has not had any intruders lol, And that one definitely has plenty of food crumbs from the kiddos sometimes
    Mendel Leisk and bisco like this.
  11. bisco
    52,779
    knock wood, gen 2 had it's share :(
