MouseProofing the Prius
Discussion in 'Knowledge Base Articles Discussion' started by ebsmythe, Jul 16, 2008.
  1. DGH
    DGH Thread Terminator
    365
    94
    Wales, WI
    As for the openings by the hood hinges, I picked up a Rigid digital inspection camera and will scan the area tonight for access to the ventilation system.
  2. PeaceKeeper
    PeaceKeeper New Member
    42
    Georgia
    I had a rat take up residence in one of my Corvettes, I worked had to trap him and finally succeeded. I used a T-Rex rat trap and that did the trick. If a rodent sets up residence in your car you can have big troubles, a rat is even worse. Rats and mice don't take a pee, they just leave a trail of urine where ever they walk.
    If you keep your car in a garage don't keep dog food, bird seed and any other food for the rodents to live on. I learned a big lesson on this when it happened to me.
  3. PeaceKeeper
    42
    Georgia
    Here is the rat I killed.
  4. deltron3030
    deltron3030 New Member
    437
    64
    Lakewood, CA
    fairly common issue really. just replace your cat filter and you should be fine
    Sezy and ChaiLove like this.
  5. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    512
    63
    This would be the first! Please keep us updated. Thanks! :)
  6. carz89
    carz89 I study nuclear science...
    444
    47
    San Diego
    Nice work and documentation! I'm assuming you keep your car outside, thus the mice problem. Mine is kept in a relative tight garage - just bugs and spiders to deal with.
    One minor comment -- being outside, the car could be subject to much humidity and moisture. Galvanized metal mesh will rust if it scratched or cut. (I admit I'm a little anal when it comes to rust prevention). I would have used stainless steel 1/4" mesh. I little more expensive, but worth it since you've gone to such great effort already to take things apart. One website I found charges $80 for a minimum order of 10 square feet.
  7. DGH
    365
    94
    Wales, WI
    Well I gave it the college try.
    Took a quick look and saw no obvious openings, however....
    The Rigid micro SeeSnake is a real pain to use.
    The "flexible shaft" is very stiff and difficult to guide.
    Plus you really get screwed up on the orientation of the camera when you are unable to see where it is pointed.
    The worst is I went back out to do a more extensive check and while giving the not so flexible shaft a custom bend the imaging head broke off the shaft!
    So sadly I can not give a definitive answer at least for a few weeks.
    When I get it back I will remove the wipers and cowl and hope for better access going through that route.
    Took some strong narcotics for pain, hope the above is somewhat coherent.
  8. 2009Prius
    2,705
    512
    63
    Well the first time is always harder. Hopefully the next time will be easier and more fruitful. Thanks for the update! :)
  9. PhiloMcGiffin
    PhiloMcGiffin New Member
    NE PA
    Please see my related post:
    GenIII - Rodent Damage - $ 900.00 also in this Forum section.
    I'll need to wrap my entire vehicle in "Mesh Screening":eek:
  10. Comrad_Durandal
    Comrad_Durandal New Member
    170
    Minneapolis, MN USA
    :eek: I've never had problems with rodents getting into my car, like....ever... Not saying it doesn't happen, just...not sure what I must be doing to keep them out or that isn't happening to let them in for all of those who are experiencing problems.
  11. bisco
    52,862
    it's hit or miss. luckily, mostly miss. who knows the right situation that sends the little buggers looking for shelter, food and warm wires to chew on!
  12. tommyandbeth
    tommyandbeth Junior Member
    28
    Arbutus,MD
    Try dryer sheets
  13. bisco
    52,862
    under the wipers?:confused:
  14. 2009Prius
    2,705
    512
    63
    If you want you can spread roasted peanuts in the air box and on top of the cabin air filter to encourage the cute little creatures to make their home there. ;)
  15. Rae Vynn
    Rae Vynn Artist In Residence
    6,038
    707
    Tumwater, WA USA
    keep a cat in your garage.
  16. bisco
    52,862
    a black cat?:D
  17. Rae Vynn
    6,038
    707
    Tumwater, WA USA
    A hungry cat.
  18. BhamPrius
    BhamPrius Member
    128
    Bellingham, WA
    All of these threads have me a bit freaked out about a mouse attack on my new 'baby.' It seems most people reporting damage are East Coasters. Is this a "major" problem--especially out West? I will be roadtripping across the country this summer, including the UP of Michigan. I'd absolutely HATE to have this rodent damage occur, especially while on vacation. Anyone have some input before I decide on whether or not to embark on the adventure of rodent-proofing my Prius?
    Side note: I see this OP owns and did the work on a G2. Has the G3 alleviated some of these incidents of rodent attacks?
  19. Patrick Wong
    18,210
    6,522
    I believe that G3 is, if anything, more susceptible to rodent damage. Look on the G3 forums for details.
    One issue in particular is that the G3 engine ECU is now located in the engine compartment (vs. Classic and 2G where the engine ECU was next to the hybrid vehicle ECU behind the glove compartment area) and the wires leading to it are exposed.
  20. MouseMachine
    MouseMachine New Member
    Santa Cruz, CA
    I have two Prii (2005 and 2006), both parked outside. Over the past two months mice are getting in both cars on a nightly basis. Originally, we had carseats with food crumbs attracting them, but that stopped when we first noticed evidence of mouse activity. (Carseats completely removed.)
    A week ago, I took one prius and performed all the screening presented in this post. That seemed to work for two days and then the mice came back. Others have mentioned the airbox as another point of entry. Has anyone done that mod and have photos of the end product? I'm willing to invest more time and effort into being mouse-free.
