Moving from California to a Freezing Snowy Area, Advice?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Snake, Oct 21, 2011.
  1. wick1ert
    wick1ert Senior Member
    1,311
    183
    Delawhere
    Your car didn't get stuck, it just decided to get back at you for taking it through such conditions again and took a break.
    I've never been to Sac before, maybe one day. How far is it from San Diego? LOL. I wanna go back to there again someday. I could even pick up that headlight :D
    I have been to San Fran, San Jose, LA, San Louis Obispo (sp?), San Diego, and a couple other smaller places.
  2. qbee42
    qbee42 My other car is a boat
    18,058
    3,079
    Northern Michigan
    50/50 is a good rule of thumb, but you can't say that any other ratio is a lesser mixture. It all depends on what factors you wish to optimize.
    Ethylene glycol is more viscous than water, and it also has a lower specific heat, which means the more glycol in your mixture, the hotter your engine will run. If maximum cooling is the requirement, you want to use a minimum of glycol - just enough to prevent corrosion. 10% to 15% is often used in these situations.
    If, however, you want the lowest possible freezing point, then you need about 70% glycol. Anything more or less freezes at a higher temperature.
    If boiling is the main factor, then you use all glycol, as it has a higher boiling point than water.
    Given all of the above, most people in cold climates elect to use a 50/50 ratio. Besides, it's easy to figure the amounts at a half each.
    Tom
  3. WE0H
    WE0H Senior Member
    3,247
    528
    I might have to rent a RAV then :p
    Mike
