Moving Heated Seats Button Switch
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Danger, Dec 25, 2011.
  1. Danger
    Danger Member
    175
    22
    Frisco
    Does anyone know if this is possible. I am starting to hate to crouch over while driving to turn the heated seats on. I want to relocate it to the left or right side of the steering wheel where there are empty plugs.
  2. DavidA
    2,349
    1,825
    Chicago western burbs
    The 2010 placement, not to mention the orientation (top is left, bottom is right), would win the all-time stupidest button placement for all cars ever made. Any place better than below the flying bridge would be far better.
    Are there blank spots remaining at the lower left part of the dash to the left of the steering wheel? That's where I would move it to, unless the passenger would want their own access to it.
  3. lpe350
    lpe350 Member
    56
    32
    Long Island
  4. Judgeless
    Judgeless Senior Member
    1,821
    257
    Cleveland, OH
    I wish someone would release an aftermarket button that had a high and low setting.
  5. fulltank
    fulltank New Member
    230
    38
    Arkansas
    Check with your dealer, pretty sure Toyota sells a crooked wooden stick with a mirror that helps with pushing these buttons.
  6. RRxing
    RRxing Senior Member
    2,563
    1,842
    NEPA
    While the button is in the worst possible location/orientation, how often do you actually have to use it? I turn it on either when I first get in the car on a frosty morning, or, make sure it is on the night before if I know I'll use the remote start the following morning. Besides those times, I hardly need to use it while driving.
  7. Danger
    Danger Member
    175
    22
    Frisco
    Ergonomics is what I'm hoping for. I am picky at which my temp is set. So I'd like to have the option of turning the heating element on/off. Lets hope the wires will be long enough to stretch to the left or right side of the steering wheel. Now does anyone know where the fog light switch should go?
  8. cap160
    cap160 Older Member
    78
    Michigan
  9. The Critic
    The Critic Resident Critic
    3,193
    2,333
    CA
    The Rostra ones do.
  10. sa177
    sa177 Junior Member
    76
    NorCal
    Does anyone know if the 2012 Hatchback heated seat buttons are in the same location as the 2010/2011s?
  11. Tracksyde
    Tracksyde Member
    1,429
    762
    So Cal
    Yes, it's in the same spot
  12. Zedknepplin
    Zedknepplin semper prius
    124
    65
    162
    Georgia
