MPG and the coolant control valve
Discussion in 'Gen 2 Prius Fuel Economy' started by GeorgeMW, Oct 9, 2017.
  1. GeorgeMW
    GeorgeMW Junior Member
    56
    Georgia
    Hello!
    my question is: does the car have worse MPG when the coolant control valve is not working?
  2. 05PreeUs
    05PreeUs Senior Member
    1,097
    563
    MSP
    The heat recovery system, that the CCV is an integral part of, is designed primarily to reduce warm-up time/maintain the coolant temperature closer to normal after being parked.
    In cases where the drive is "normal", eg: 8 miles or more one way at near highway speeds, I doubt there would be any noticeable difference. In point-of-fact, cars delivered in a number of markets do not even have this system installed.
    m.wynn likes this.
  3. MilkyWay
    MilkyWay Active Member
    819
    357
    23
    MI
    I just got a 2006 Prius that had no heat. Showed 34-36mpg on the screen!
    Changed thermostat first (didn't fix heat) and then mechanic ran code that said coolant control valve. His scanner also picked up a misfire cylinder 3....Keep in mind I had zero warning lights on the dash.
    Long story short the control valve brought back heat....and the spark plugs were really shot too! And my mpg immediately jumped to about 41-42mpg on the screen.
    So hard to say if it was plugs or the valve...or combo of both.
    But, wouldn't you think with bad CCV the computer would be tricked into thinking that the car is operating cold and run the gas motor for longer periods of time...and thereby ruining mpg? I am probably messing the mechanic lingo up (I'm really bad with cars) but I read something similar to that here before. That a bad CCV runs gas motor longer.
  4. 05PreeUs
    1,097
    563
    MSP
    Not if you are driving the car at speeds above 20 MPH, the engine is running ALL the time.
    The ONLY part of the cooling system that controls engine temperature is the thermostat, it's more likely when replaced some residual air was trapped in the system that was purged when the CCV was replaced, returning the heater to normal operation.
    MilkyWay likes this.
  5. MilkyWay
    819
    357
    23
    MI
    I replaced thermostat/CCV at exact same time...And got air out of system same time. And changed spark plugs same time.
    For weeks MPG on display was 34-36 tops....After repair jumped to 41-42. Spark plugs were shot but didn't drive like they were shot. 161,000 miles.
    Data Daedalus likes this.
