MPG city vs freeway
Discussion in 'Gen 4 Prius Main Forum' started by Buggs1a, Jun 3, 2025.
  1. Danno5060
    Danno5060 Active Member
    405
    209
    Wyoming
    The speed limit on the highways around here is 80 MPH for the interstate highways and 70 MPH for the two-lane state highways. My wife teaches at a rural school about 50 miles away from here, so she drives the 2019 Prime. 20 miles of that is on the interstate, 25 is on the state highway, and 5 miles of that is around town.
    Wind resistance at the highway speeds is proportional to the speed squared. There's a sweet spot for speed, below which you're not putting on the miles to get the best miles per gallon. There's also a point where gonig faster takes more power to push the car through the air so you don't get the optimal miles per gallon. Also, on the highway I don't get any benefit from the hybrid. Around town, I can cycle the energy from braking to the next acceleration. On the highway, at least with the relatively little traffic around here, we don't really stepon the brakes that much.
    Also, there's the impact from the plugin, since I have a Prime. We can actually use the EV, but for only 20-25 miles per day though. The highway sucks that down much faster than around town.
    That being said, we get around 70 MPG (treating the EV miles as free miles) because of the highway speeds.
  2. Mendel Leisk
    42,343
    This, coupled with "stop and go", is never going to yield good mpg. If on the other hand you were tooling around town all day, like a cab, I think you'd see stellar mpg, calculated from fill-ups and distance travelled.
  3. kevinwhite
    kevinwhite Active Member
    333
    200
    Los Gatos Ca
    Short journeys will result in low fuel efficiency as th engine spends much of the time arming up to optimum temperature. If all your short journeys are like that it would explain your poor mileage under city conditions.
    My commute fuel consumption is mainly for journeys that are 30-40 minutes in duration.
    The EPA figures are with the engine hot.
    kw
  4. Buggs1a
    Buggs1a Junior Member
    112
    It’s nice I’m getting what shows on screen over 60 mpg on freeway. Sometimes 69 mpg from my moms/sisters to my place. Some not freeway but using cc most of the time. Lucky.
    I know the car what it snows isn’t perfect. But it’s nice anyway :). Wish it was perfectly accurate.
  5. bisco
    52,847
    no car is perfect (or anything else for that matter) you got the right one for you!
  6. Buggs1a
    112
    I hope I got the right car for me. Money sucks. And the well anyway. Higher mpg numbers even if not 100% is better.
  7. bisco
    52,847
    I remember when I couldn’t afford a decent car, and had to learn how to do all the maintenance and repairs.
    It wasn’t easy, but I did learn a lot, the hard way
  8. Buggs1a
    112
    Hey guys. I thank you all for being cool here and friendly. I’m learning from you all. And I appreciate all of you very much.
  9. Billy56
    Billy56 Member
    83
    83
    Seattle, WA
    2020 Prius
    L Eco
    BUGGS1.....you have got this all backwards. This is a topic I am intimately familiar with.....believe me. I also, like you, have a 2020 L Exo.....with 473,000 miles on it. The reason YOU get better MPG on highway is the way you drive. A skilled hypermiler will get FAR better MPG in the city!
    You must understand the above about 34 MPH, aerodynamic drag is the biggest thing you are fighting against! The faster you go, the worse it is. Around town I average aprox 88 mpg in warm weather. On freeway I can only achieve aprox 75 MPG. I am an experienced hypermiler with over 3.3 million miles since 1978. To learn momentum, braking, and lane position techniques I suggest cleanmpg.com or take some instruction with Wayne Gerdes.
    VelvetFoot likes this.
