Mpg decrease after getting new tires?
Discussion in 'Gen 2 Prius Fuel Economy' started by MindHalfGone, Feb 13, 2019.
  1. MindHalfGone
    MindHalfGone Junior Member
    california
    Hello, I'm sure there are tons of forums on this but have not been able to find any good responses or fixes. About a month ago I changed the back tires from good year assurance tires to Hankook st 88t tires, the mileage did not decrease until about a week ago I had the front 2 assurances replaced with another set of 2 hankook st 88t tires. Since then I've seen a pretty bad drop in my MPG, it is winter but I live in socal so the temps dont go lower than 50 until late at night/early morning. I change my oil regularly (synthetic) just put a new air filter, had the Hybrid battery changed with a 5 year warranty. The tires seem to be the culprit, would breaking these tires in cause my mpg to drop so significantly, I was getting over 400 miles per tank and now I'm getting 340 to 350...
    52,863
    welcome!
    i hate to say it, but it's more likely the rebuilt hybrid battery, but.
    the best way to track your mpg's is a manual calculation every time you fill up. then watch the long term averages.
    the gen 2 has a fuel tank bladder which wreaks havoc with capacity, and thus, tank miles or mpg calculations.
    and 50 degrees is nothing to sneeze at, batteries start to lose performance under 70 degrees, not to mention engine warm up and temp maintenance, along with any cabin heat you may be asking for.
    Mendel Leisk and MindHalfGone like this.
  3. litesong
    litesong Active Member
    371
    122
    Everett, WA
    On our two Elantras (auto & manual), we have Goodyear Assurance Touring tires on one & a mix of Hankook 431s, Yokohamas, & Kumoh Solus tires, all of greater tread width & sometimes, greater height than the Assurances. As I have changed the various brands, I have NOT determined any greater fuel consumption among the three & can NOT state that I find them, either more or less, efficient than the Assurances on the other Elantra. I have always gotten good MPG with my cars, whether the cars &/or the tires have been new.
    #3 litesong, Feb 13, 2019
    MindHalfGone likes this.
  4. George W
    George W Senior Member
    939
    520
    San Antonio
    With new tread it's possible you could benefit from a wheel alignment.
  5. dolj
    dolj Senior Member
    8,652
    4,402
    Wellington, New Zealand
    I hate to say it as well, but I agree with bisco. It is your rebuilt battery that is the most likely cause.
  6. MindHalfGone
    california
    Thanks!
    Why would you assume its the rebuilt battery? I still have a 4 year warranty on it so if that's the case I can get it swapped, I was getting great gas mileage before i switched the front 2 tires, I was also told I do need an alignment but am fighting with my insurance company to have it fixed because of issues I had last year. Could having the 2 new tires put on with my alignment off cause the MPG to drop and i'm noticing it more with newer tires? (Odometer is 137k+) miles.
    Also I checked the 12v With the diagnostic menu the car offers, It was at 14 volts when the car was turned on and running. I do also know that the cold can cause a MPG drop but it just seems so SUDDEN, If it is the Rebuilt Hybrid Battery I'll be taking it in to my mechanic and have him test it to make sure that the rebuilt battery is still working as it should.
    What PSI do you recommend? I'm just going with what the car says with 35front and 33rear.
  7. MindHalfGone
    california
    Yes, I have been told this. Waiting on my insurance to have this problem fixed, do you think I would notice the MPG drop more with newer tires and the alignment being off? Because the alignment has been off even before the 2 new front tires, new tires = more noticable?
  8. dolj
    dolj Senior Member
    8,652
    4,402
    That is fine. Just remember to check them often and particularly when the weather changes. When it gets cooler the pressure in your tires will fall. It only takes 1 or 2 PSI lower than what you're running to affect the MPG.
    There shouldn't be any effect because of the alignment. The only way you would notice anything would be the new tires, and the MPG would only be less if the new tires had a higher rolling resistance when compared to the previous tires.
    If the Hankooks are the Kinergy variant, then they are supposed to be LRR, but they still might have a higher RR than the GoodYear Assurances.
  9. bisco
    52,863
    if it happened when you put them on, it would make sense. but dropping after month doesn't.
    rebuilt batteries can be sub par, affecting mpg, but not throwing a code.
    i think it would be best for you to track a few tankfuls and calculate your mpg's.
    how long have you owned the car?
    the 12v volt needs to be measured with the car not in ready
  10. MindHalfGone
    california
    I understand rebuilt batteries can be sub par depending on where you get them, My mechanic is a Aes certified mechanic and he has been amazing to take my car to. I've owned the car around 2 years now.
    I just measured the 12v when the car is not in ready and it dipped to 11.7-11.9 (did I find my problem)
  11. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    I think it's the tires.
    New Tread has a higher rolling resistance.
    If originally you had new ONLY on the back, and didn't notice a decrease until putting new on the front? I'm going with the tires, as the Prius is front wheel drive. The new tires on the drive wheels have lowered your MPG. I would expect it to improve with better weather and as the tires break in.
    If it was your Hybrid battery, I'd expect some inconsistency on your battery charge display and/or some codes. You don't seem to be displaying any other symptoms BUT lower MPG.
    I could be wrong. But I'm putting my money on tires. Also..maybe an alignment would help.
  12. The Electric Me
    9,083
    5,801
    Please note, I said I could be wrong.
    The good news (bad news) would be, if it is your Hybrid Battery, you'll eventually know that for sure. As your mileage will not improve and more symptoms will arise.
    But let's be optimistic and just hope it's the tires.
  13. George W
    939
    520
    San Antonio
    it made a noticeable difference in my case, and I only had 1 wheel off by 2 degrees
  14. George W
    939
    520
    San Antonio
    Many here use a balance of 42 front, 40 rear. The tires` max psi is stenciled on your sidewalls. In my case the 16" tread has 55psi max, so I use the 42/40 to minimize road contact, but not high to create the bouncing sensation.
  15. bisco
    52,863
    borderline 12v. more testing would be needed, probably a load test. how old is it?
  16. MindHalfGone
    california
    Older than I know, lol. It's been in the car since i bought it.
  17. willakwin
    willakwin New Member
    NEW YORK
    2011 Prius+ MPV
    it happens some time i also feel this issue in 24 Hour NYC Towing Services truck, i was thinking that maybe there some issue in the vehicle after some research i realize that it's normal. no need to worry about this.
  18. bisco
    52,863
    worry about what?
  19. Bob Welcher
    Bob Welcher Junior Member
    Columbus Ohio
    I just replaced the OEM Dunlop titles on my 2021 Prius Prime 27,000 miles (?!) with Michelin Defenders. My mileage immediately went from 54 mpg average to 40 mpg in a 400 mile trip. Always average 54 mpg or better. Nothing else changes on the Prius.
    I have had Michelin Senergy on my previous 2010 Prius, but I was told they were dicontinued. No alignment issue or battery - just new tires.
    I'm going back to Discount Tires and take advantage of their return policy, switching to a tire made for high mpg, with less roll restistance. I found that Michelin does gave a high mpg tire, the Michelin Energy Saver A/S.
  20. Mendel Leisk
    42,355
    Michelin seems to be using LRR (Low Rolling Resistance) label indiscriminately. A few years back I swapped from well-worn Michelin PIlot hx MXM4 OEM's on ours, to Primacy MXM4. Both had the Green-X label, Michelin's LRR badge. The new Primacy's really tanked our mpg for a few years, finally climbing back now.
