MPG decrease with new wheels
Discussion in 'Gen 3 Prius Fuel Economy' started by trentofdestiny, Jan 30, 2014.
  1. trentofdestiny
    trentofdestiny Master Finagler
    1,104
    227
    Harrisburg, PA
    That's only with the stock tire size 215/45/17. I'll be using 205/50/17 which are very close in diameter to 195/65/15.
  2. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    If he goes with the 205/50/17 the diameter will actually be slightly larger than the OE 15" tire. :)
    trentofdestiny likes this.
  3. SAronian
    SAronian Active Member
    334
    144
    Oakland, CA
    With all the speculation about tire/wheel size's effect on fuel economy, I find it interesting to note the approach BMW has taken using 155/70R-19 Bridgestone's on their new i3. I suppose the diameter is a styling choice and the narrow width is to enhance efficiency.
  4. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Sort of and yes.
    Larger diameter wheels is the general trend for vehicle styling. The larger diameter also helps maintain a properly sized tread footprint for safe braking and handling. The only way to get around the negatives of large diameter wheels is to make them very narrow to reduce weight and improve aerodynamics. Because the i3 is considered more of a city car, the narrow tires help improve agility at medium to low speeds and reduce aero drag at medium to high speeds.in general larger diameter tires increase efficiency but on the Prius, you suffer losses associated with tire/wheel width, weight, aerodynamic drag, etc.. Unfortunately they don't have a tire available to accomplish what BMW did. I.e. A very narrow 17-18 wheel coupled with a 175 or smaller tire.
    SAronian likes this.
  5. trentofdestiny
    1,104
    227
    Harrisburg, PA
