Mpg deviation
Discussion in 'Gen 2 Prius Fuel Economy' started by lpf, Feb 15, 2022.
  1. lpf
    lpf Member
    139
    39
    Greece
    for the first time I Note deviation between the consumption on the screen and the consumption I get from Hybrid Assistant app. E.g. MFD says 5.2 l/100 and Hybrid Assistant 5.8 l/100. The later has been confirmed at the gas station.
    I don't know what the reason is but I suspect that the tank sensor sends wrong level?
    Thanks
  2. jerrymildred
    jerrymildred Senior Member
    11,517
    14,170
    Tampa, FL
    Not related to the fuel level sensor. It's because the system in all Prii is very optimistic in measuring the rate of fuel consumption against the distance traveled. Most people just mentally adjust what they see on the MFD to compensate. If you track the fuel use and miles over several tanks, you can get a pretty close approximation.
    But it's worse in North America. In the North American 2nd generation Prius, there's an extra complication that I don't think you have in Europe. We have a rubber bladder in the tank. It varies in flexibility as the temperature changes. That means that, in cold weather, the gas station pump often shuts off sooner than it would in hot weather.
  3. lpf
    lpf Member
    139
    39
    Greece
    Thanks. I always trust the gas station, what is the fuel-up is exaclty what burned for the given mileage.
    On the other hand I've never noticed so much deviation in the app, as this time.
  4. jerrymildred
    11,517
    14,170
    Tampa, FL
  5. lpf
    lpf Member
    139
    39
    Greece
    23 months so far, 51,000km
    jerrymildred likes this.
