MPG Difference of 0w20 vs 5w20
Discussion in 'Gen 3 Prius Fuel Economy' started by Siward, Apr 13, 2015.
  1. JC91006
    16,936
    8,647
    This engine seems so new and strong still, I don't know if engine flushes will help or cause more damage. Adding oil doesn't bother me, I've been doing it on my 2006 forever.
  2. Former Member 68813
    3,524
    983
    US
    engine flush done correctly (just idling a few minutes and engine not grossly sludged) doesn't damage anything. and you have a chance to test a hypothesis and potentially reverse a spiraling chain of events. but, it's your own choice.
  3. JC91006
    16,936
    8,647
    Seeing that I don't know the cause, it would be hard for me to try to fix it. I'm trying the natural cleaning method by using pennzoil ultra platinum synthetic oil, it's the cleanest out there.
    I tried treatments of MMO on my 2006, didn't work at all.
  4. Former Member 68813
    3,524
    983
    US
    i agree, in my own experience, MMO is near useless. besides, if you wait too long, nothing will fix it, as oil deposits turn into hard carbon with time.
  5. Dave14Prius
    Dave14Prius Member
    72
    26
    NE Missouri
    Depending on where you bought it, exchange it at the store. Walmart exchanged mine without a receipt, no problem. That said, I'd guess the mpg hit would be less than 1 mpg, if that.
  6. Redpoint5
    Redpoint5 Senior Member
    1,026
    509
    Portland, OR
    I'm changing the oil in the Prius today and found some 5w-20 Amsoil laying around in the garage. I'll never use it unless I go with it today.
    I'm still wondering how much of a MPG hit I'll have with cold starts compared to the 0w-20? It's about $25 in oil, and I doubt I'll burn more than that in extra fuel due to the thicker oil.
  7. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
    Geez I'd be using the AMSOIL up shoot me.
  8. Redpoint5
    1,026
    509
    Portland, OR
    I'd give it to you if we were close by. Don't know how I ended up buying it, but my guess is it was incorrectly stocked with the 10w-40 I bought for my motorcycle.
  9. Siward
    Siward Active Member
    314
    128
    Toronto
    It's been on year since my original post. I've been using 5w20 for two oil changes in the spring-fall. I switched back to 0w20 synthetic in the winter.
    I don't find any noticeable difference. The higher summer temperatures make the "5w" part pretty unnoticeable. I can't comment on cold starts as I've never used the 5w20 in the winter.
  10. bisco
    52,812
    thanks for the update!(y)
  11. Redpoint5
    1,026
    509
    Portland, OR
    I'll be experimenting with 5w-20 in the winter since I go a year between oil changes. If I notice any differences I'll report it here... in a year.
  12. QuantumFireball
    QuantumFireball Active Member
    420
    269
    Ireland
    In case you're wondering, the European manual has much more lenient oil requirements:
    They do push for 0W-20 though.
    Semi-synthetic oil is pretty much the default here for any car made in the past 25 years or so. Mineral oil (if that's what you mean by "conventional" or "dino") is for classic cars :)
    Redpoint5 likes this.
  13. Former Member 68813
    3,524
    983
    US
    how do you drive your prius again?
