MPG: DRCC vs Self Driving
Discussion in 'Prime Fuel Economy & EV Range' started by stevepea, Jun 11, 2017.
  1. stevepea
    stevepea Senior Member
    535
    581
    For a highway-speed freeway trip (ie, the proverbial easy "Sunday Drive"), have you found the EV Range and/or HV MPG to be better when cruise control is on, or driving it yourself without cruise control?
    Not talking about comfort/ease vs wanting to be in control -- just asking purely about MPG.
    In all my years driving, I generally never use cruise control, so just curious.
    But this weekend, had a chance to try out the DRCC on a longer, fast (65mph) freeway drive.
    First of all, a quirk with the Prime in HV Mode:
    On the Prime, I noticed when in HV, if you leave your foot on the pedal constantly (even super lightly), it will stay in "gas" mode longer, and only switch to temporary-EV spurts after a long while. However if you take your foot off the pedal for just a second, then put it back on the pedal, it'll usually switch to a temporary-EV spurt for the standard 10-20 seconds (before going back to gas). So when in HV Mode, if you lift your foot off the gas for a sec and then put it back, oftentimes a temporary EV spurt will come on for 15 secs or so. If you just kept your foot down constantly (even really light) it waits quite a lot longer before doing those short EV spurts.
    I mention the above, because DRCC seemed to operate a lot like just keeping your foot lightly on the pedal (ie, the EV spurts don't come as often). When I turned on the DRCC, it took almost 4 minutes (of 65mph 405 driving) for the first temporary EV-spurt to occur. If I had driven it myself and taken the foot off the pedal for a second, then put it right back on, a temporary EV-spurt would've occurred right away. The EV spurts certainly improve your MPG -- but typically the car will then try to "recharge" the amount used up in the spurts (even if your traction battery is close to full). So not sure how much of a benefit it is.
    However, it seemed to me (though I only tried the DRCC once) that self-driving did get better MPG than DRCC -- but that may be because of false factors, like when self-driving, as much as I tried to keep the speed steady, if I got to a slight incline, I noticed the speedometer dropping to 61 or so (which the DRCC did a better job of keeping steady), and I'd have to then react and bring it back up, so maybe the better MPG was because of factors like this. Still (for whatever reason) I seemed to get better MPG on my own than with the DRCC, though again if it was because of false factors like me not always keeping up the same exact speed, I'm not sure.
    So that's why I'm asking others what they have found. Is it about the same? Better self-driving? Or better with the Cruise Control?
    Also, a question: I assume this was just a fluke, but wanted to ask just to make sure. When I "set" my speed for the cruise control, the speedometer showed I was going 66. But the DRCC was then set (and kept it) at 65 (the speed limit of the area) instead of 66. I assume it was just a fluke (maybe it dropped to 65 for a split second that I didn't notice)... or does the DRCC not let you "set" to anything over the speed limit?
    Silent Propulsion likes this.
  2. alexcue
    alexcue Active Member
    346
    311
    So Cal
    I've set the DRCC to 80, no isuues. Maintains it just fine.
    I guess that's why I don't get 35MPG on EV my usual speed on the 210 is about 73.
    joachimz and stevepea like this.
  3. joachimz
    joachimz Senior Member
    451
    612
    17
    SoCal
    I have set the DRCC even higher than that no issues ...
    I have developed the habit while i had my Gen3 to always use cruise control on fwy as well as any roads, city and hwy, > 45. I found that the car was able to maintain speed better than I with my foot, and keeping the speed as constant as possible increases mpg, at least for me.
    I continue to do the same with the Prime, for the same reason.
    #3 joachimz, Jun 11, 2017
    stevepea likes this.
  4. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
    On my US 2 trip I set my speed to 76 MPH had no issues whether the speed limit was 80, 70 or 65, but when approaching another vehicle that was going slower than 76 MPH the DRCC would kick in, lowering my speed accordingly until I switched to the left lane whereupon the speed would resume to 76 MPH. The DRCC also "sees" motorcycles.:cool:
  5. HypersonicPrime
    75
    59
    NC, USA
    Hey @stevepea. I had a similar question and I thought I'd give my experience. At, say, 60 mph, yes the cruise control (DRCC on, but probably the same if it is off) seems to keep the gasoline engine on for moderate downhills, whereas manual control you can let off the pedal and encourage EV driving until the next hill. I haven't done this in a controlled fashion for accurate comparison, but my feeling is that it will improve mpg because I'm sure the increase in mpg while the engine is off is less than the decrease due to increased engine speed on the hill or on flats or additional time-on to recharge that lost-charge from EV driving. Sometimes I let off the pedal on a downhill and EV mode does not engage--I assume because the "HV battery range level" is too low. Will this method of driving put slightly more strain on the engine or maybe MG2 to start/stop the engine more often, negating the mpg benefit?
    As an interesting side-question, I considered manually switching the car to EV Mode on downhills and back to HV on flats or uphills. I did this for 10-20 miles recently. Aside from a lot of button-pushing, if you start with a full battery, I wonder if this would be more efficient than both cruise control or the manual pedal control. Because each re-engagement of HV sets a new starting point for the battery level (right?), I bet the level would deplete over a long trip ending the ability to do this without engaging charge mode.
    As for your second question, yes my DRCC set speed is sometimes 1mph different than my speedometer. I'm not sure why but it's never more than 1mph different. Maybe it's rounding or they are calculating their speed data differently.
  6. stevepea
    535
    581
    Glad to hear the 1mph difference isn't just my car (not a big deal, but was curious about it). As for the "manual" driving (giving more temp EV spurts than cruise control does), I seem to get better MPG that way, but it could very well be because I lose a bit of speed by doing so. I do find it interesting that if one wants, you can force a lot of temp EV driving for better MPG (after a while, the car will take more gas to bring the battery back up to where it was) or you can just leave your foot on the gas (or use cruise) with mostly gas instead of temp EV/recharge cycles...
    By the way, as for hills, I found that steep hills are better in EV (going up) as long as you have enough EV range left to still be able to be in EV for going DOWN the hill later (to partially recharge it back up with "B" mode). There's a drive I take a half dozen times a year where there's a really steep hill at the end (and at the beginning when returning). I found that if I'm in HV mode, it uses a lot of gas to go up, and going down it requires constant braking so much of the benefit of going down is lost. But if I'm in EV mode, it uses more battery going up of course, but if I can still be in EV mode for the return, that trip down really helps recharge the battery back up in "B" mode (and saves from having to use the brakes as much as a side benefit).
    HypersonicPrime likes this.
  7. Tideland Prius
    16,668
    Wait so why is the downhill side different in HV or EV mode? (or are you talking about recouping energy that was lost in HV vs. EV mode... i.e. a relative comparison?). I would think the amount regenerated would be the same in either EV or HV mode.
  8. stevepea
    535
    581
    I guess you're right in a way, except that if you've run out of EV range and are in HV, and go down a steep hill for a bit, if I remember right (I only did it this way once), it has to recharge to a certain amount before it will let you access it as EV again (not just for a little bit), whereas if you still have some EV range left and are in EV, then you can use every little bit of charge you get by going downhill if you're still in EV.
    As far as ICE vs EV on a hill, though this is by no means scientific, I noticed that if I can do the entire trip (up and down a long steep hill) all in EV, the by the time my range runs out later on, it's only lessened by a bit (ie, the "coming down" put back not all, but much of the extra energy needed by "going up"). So if I usually get 33.0 miles on flat stop-and-start driving (just as an example) maybe I'll get something like 32.5 (or thereabouts -- this is just an example) including going up that steep hill, then going down it, as long as it's all in EV and "B" mode on the way down.
    But if I did the same trip in HV mode, it would eat up a lot more gas going up the steep hill, and I don't think it would "return" as well on the way down, especially if the EV range is gone and the car is in HV mode. I could be wrong, but that's the feeling I get. Could just be my imagination
    Tideland Prius likes this.
  9. HypersonicPrime
    75
    59
    NC, USA
    For a slightly different strategy, you might find this post interesting.
  10. SteveMucc
    SteveMucc Active Member
    391
    268
    Kentucky
    if ( current_speed < set_speed ) increase_velocity;
    if that's the case it shouldn't ever accelerate using the engine to greater than the set speed.
