MPG drop after prepurchase inspection at Toyota Dealer
Discussion in 'Gen 2 Prius Fuel Economy' started by elephanyeyes, Mar 16, 2017.
  1. elephanyeyes
    elephanyeyes Junior Member
    Portland, OR
    I just took a 2007 Prius that the previous owner's odometer read 300 miles and 42 mpg. On my test drive I reset the odometer and tested it with my driving and I was getting 50+ mpg around town. Then I took it to the dealer for a prepurchase inspection and when I got it back (and then bought it) it's been getting 28mpg in the city. This is with me driving 30 mph around town and not leadfooting it. Also, strangely when I switch to the energy view as opposed to the consumption view it shows me getting 40-55mpg while driving 30mph, not the 28mpg that it shows on the consumption view. I understand that the cruising mpg is not the overall mpg, but I'm not accelerating hard enough to warrant such a drop.
    So, could Toyota have done something on the inspection that would have messed up the fuel economy? the 12v battery is at 11.8v and they suggested I replace it asap. Thanks!
  2. CooCooCaChoo
    CooCooCaChoo Active Member
    888
    494
    Cow-lee-fornia
    2023 Prius
    Did you check the 12v battery yourself or did the dealer check the battery? When its off, battery should read in the high 12.x range, and when running should read in the 14.x range.
    And yeah the 12v battery can cause problems if it can't hold a charge.
    48,996
    it's hard to gauge mpg's instantaneously. agree with above, test bad when cold, and replace if necessary.
    try resetting the trip meter and take a 20 mile drive under varied conditions, then see what the average is.
  4. uart
    uart Senior Member
    4,215
    1,200
    Australia
    Just drive it for a few tanks full and then reset the MPG and see how you go.
    There are several things that they could have done, none of them serious. They could have:
    - Had it idling in inspection mode for some time, which will serious impact the average MPG for a while.
    - Discharged and then force charged the traction battery. Similar to the above.
    - Had it sitting in accessory mode and let the 12V battery run down a bit. This can effect the MPG for a while. (Retest the 12V after a few weeks of driving)
    - Had the 12V battery disconnected which resets some of the calibration data that it uses to tweak the MPG calculations. This can effect the calculated (displayed) MPG for quite a while.
    None of these things are serious. At the worst the 12V battery might be have impaired a little, but it would have to be fairly marginal in the first place, so no great loss. Just retest it after a few weeks, it will probably be fine.
    srellim234 likes this.
  5. elephanyeyes
    Portland, OR
    Thanks! Great answer!
  6. elephanyeyes
    Portland, OR
    Would the top three explanations not affect highway mpg and only city mpg?
  7. bisco
    48,996
    i don't think any of us understand how you are reading mpg's.
  8. wjtracy
    wjtracy Senior Member
    11,314
    3,588
    Northern VA (NoVA)
    Gen2 12v batt discharges on sitting for weeks, there is a button under steering wheel to turn off SKS and help 12v stay charged on a Gen2. Gen3 it was done automatically (no button needed).
