MPG drop from 65mpg to 35mpg in the last 4 weeks
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Steveurie, Jan 28, 2023.
  1. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,803
    2017 Prius c
    I won't get involved in this ridiculous claim, except to point out:
    Simple math, which some find is not really so simple.............
    Should tell you that in order to achieve an AVERAGE of 67 MPG, you must travel a significant number of miles OVER that figure.
    Because there is automatically a significant number of miles involved that are BELOW that, which you can not eliminate.
    The math just doesn't work out.
    Unless you are driving a plugin or are somehow forcing your conventional hybrid to run in EV mode
    and are then recharging the battery by MAGIC instead of via the gas engine.
  2. vvillovv
    vvillovv Senior Member
    4,321
    1,510
    NY
    as ridiculous as it may sound to others, does not make it impossible. @Grit already described above one big reason it could be possible for him, where it might not be possible for you. see if you can find it above.
  3. sam spade 2
    7,035
    2,803
    2017 Prius c
    I don't give a TLRA how or why he did it.
    It is not relevant to a conversation about "normal" driving.
  4. vvillovv
    4,321
    1,510
    NY
    As usual? Lucy?
  5. sam spade 2
    7,035
    2,803
    2017 Prius c
    Stuff it, Dufus.
  6. vvillovv
    4,321
    1,510
    NY
  7. bisco
    51,937
    it's funny how someone getting excellent mpg's can burn others backsides :p
  8. CR94
    CR94 Senior Member
    2,694
    1,173
    Northwestern S.C.
    65 mpg is very possible under good conditions, even if he means US gallons. If that's London England, not London, Kentucky, their gallons is about 1.2 US gallons.
  9. Steveurie
    Steveurie New Member
    london
    Thanks all….all I know is that I am getting a LOT less than I was and that is what I am asking….not whether the computer is right or whether I am in a dream world………sorry to spark off such a heated debate…. Quick last question….how can I get my MPG up again please?
  10. Steveurie
    london
    In London England, where it is cold and rainy by the way….
  11. sam spade 2
    7,035
    2,803
    2017 Prius c
    Selective quoting (out of context) is not nice.
    The whole statement was:
    "It is a shame that you actually believe that you EVER were getting a true 65 MPG.......or anywhere close to that.......because it just is not possible with normal driving."
  12. BiomedO1
    BiomedO1 Senior Member
    3,614
    1,869
    SacTown, Ca
    Relax Sam; it's just the politician in them or they just want to be trolls.
  13. ColoradoCrow
    ColoradoCrow Senior Member
    1,108
    463
    Leawood, KS
    I
    Actual Mileage on our last trip out West. Had a Snowboard rack and roof box mounted on top. Full car....and a headwind of 40mph the whole way. I was amazed.
  14. ColoradoBoo
    ColoradoBoo Senior Member
    1,241
    829
    Monument, Colorado USA
    You said the MPG's seemed to drop significantly after you had her serviced. What services did you have done?
  15. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    Feelings over facts?
    I drove downhill only for those 5000 miles in the photo I posted. Definitely not normal driving!!!
    vvillovv likes this.
  16. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    OP move this reply to gen 2 and begin enforcing forum rules of proper post in Prius gen models
  17. bisco
    51,937
    no offense steve, but you have ignored suggestions already offered
    Grit likes this.
  18. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    This user didn’t preface his og post that only certain answers are allowed. That one feller from Canada did that, I still laugh til this day
  19. vvillovv
    4,321
    1,510
    NY
    The Prius also has a traction pack that can have an effect of the cars mpg.
    2010 prius in london uk with a new engine air filter installed and around 100k miles
    imperial gals. ?
  20. nicoj36
    nicoj36 Active Member
    518
    162
    Forgot to add, clean your MAF sensor. I just did mine for the first time at 138k miles. MPG went up by 5 and acceleration/idle got smoother. Use CRC maf cleaner and don't touch the bottom part of the sensor. Only hold it from the top.
    ColoradoBoo likes this.
