MPG gain over G2
Discussion in 'Gen 3 Prius Main Forum' started by jeffk, Jan 24, 2009.
  1. jeffk
    jeffk New Member
    Any one heard or have data on where most of the mpg gain will be? I am interested in knowing if most of the gain will show up on the highway (because of the larger engine) or if it is in the city.
    This effects my decision to upgrade or not as I drive my 07 about 700 miles a week with an honest 85% being highway.
    Thanks!
  2. john1701a
    john1701a Prius Guru
    12,761
    5,247
    57
    Patience.
    It will take an entire year to gather that real-world data.
    Those of us in the north (like me!) will likely experience the greatest benefit, due to the heating improvements.
  3. jeffk
    jeffk New Member
    Yes I agree.
    I was just hoping Toyota gave an indication as to what we could expect.
    You are right for sure about those of you in the north. Even I in southern pa will enjoy a benefit from that!
    Looking forward to it!
  4. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    2,999
    Fort Lee, NJ
    2010 Prius with 15" rims will gain 3 City MPG and 4 Highway MPG over the Iconic Prius. This is with 10mm wider tires.
  5. Stefx
    Stefx Member
    336
    What are the heating improvements? Do you mean bigger engine = more heat, or did I miss something?
  6. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    There is a heat exchanger on the exhaust system. It is used to heat the engine coolant.
    Tom
  7. ken1784
    ken1784 SuperMID designer
    2,943
    1,374
    67
    Yokohama, JAPAN
    There is a Chief Engineer's interview article on Japanese site.
    • 2010 Prius improves aerodynamics
    • The reason of using 1.8L engine from 1.5L is for increasing fuel economy
    • We see 10% rpm down on highway, then it is very meaningful data
    • Especially at 100km/h(62mph) to 120km(75mph) area, we expect big mpg gain
    Because of weight increase, I predict we'll see more EPA highway mpg increasing than city, such as +9% highway and +7% city.
    Unnamed source says +10% at around 70mph.
    Ken@Japan
  8. john1701a
    12,761
    5,247
    57
    That's a devastating blow for the hybrid antagonist and Two-Mode supporters, since both argued highway efficiency wasn't enough. This improvement will definitely be enjoyed.
    Dang! The next 4-5 months is going to be a looooong delivery wait.
  9. ken1784
    2,943
    1,374
    67
    Yokohama, JAPAN
    I agree.
    Another Japanese magazine wrote "One of Toyota's targets is beating European diesels on highway mileage number".
    Ken@Japan
  10. spwolf
    spwolf Senior Member
    3,156
    440
    Eastern Europe
    highway numbers are especially important for press and bragging rights... so when some smart butt decides to drive Prius vs 5 series diesel on long highway journey, Prius will win this time :). Those very superficial comparos are really silly, but not many people understand how silly they are.
    RX450h also got considerably better highway numbers than before.
    I think better heat retention will help the most in europe as it will help a lot during our short city rides where prius previously wouldnt be able to heat up before we arrived at destination.
  11. Stefx
    Stefx Member
    336
    Does the new engine have direct injection? One of my previous cars (MazdaSpeed6) had that. It can boost HP for the same size engine, or keep the same HP but improve fuel economy (such as on the regular non-turbo Mini Cooper)
    Not sure if/how direct injection would work on a Atkinson modified cycle though. That would mean a fuel/air mixture would go upstream as the intake valve stays open for a while during the piston-up movement.
  12. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    A/F goes upstream w/ delayed intake valve close cycle anyway. This engine was not listed as being direct injection.
  13. Stefx
    Stefx Member
    336
    I know
    What I mean is that in a direct injection engine, there is no F/A mixture upstream of the intake valve. For this reason it might be impossible/difficult to implement a direct injection system in an Atkinson engine
  14. usbseawolf2000
    14,487
    2,999
    Fort Lee, NJ
    Very interesting and challenging! Diesel fuel has ~15% more energy than 87 Oct gasoline to begin with. It will be an incredible achievement!
    I can't wait to see the stunt highway MPG comparison of the 2010 Prius with the Jetta TDI. Will the diesel supporters have the balls to attempt another stunt?
  15. bwilson4web
    15,596
    Most of the improvement is in the vehicle. There is no single part or subsystem that by itself accounts for all of the performance improvement.
    Understand that 'city' and 'highway' performance are not 'zero sum.' You don't get one by robbing the other. So let us look at the NHW20 model rating:
    • 46 MPG Combined
    • 48 MPG city (Combined + 2 MPG)
    • 45 MPG highway (Combined -1 MPG)
    Now Toyota projects a combined MPG for the 2010 model:
    • 50 MPG Combined
    • ? MPG city
    • ? MPG highway
    So let's just assume that 'city' and 'highway' mileage differs by the same values as the NHW20:
    • 50 MPG Combined
    • 52 MPG city (Combined +2 MPG)
    • 49 MPG highway (Combined -1 MPG)
    We could use a linear relationship but those numbers should come very close to the same result.
    I was going to ask why knowing the 'city' and 'highway' mileage on Sunday, January 25, allows making a decision that can not be executed until April at the earliest and more likely June or July. But upon reflection, I prefer answers found in math and physics.
  16. usbseawolf2000
    14,487
    2,999
    Fort Lee, NJ
    Bob,
    We know the numbers already. See the picture I took from the chief engineer's notebook.
    2009 with 15" = 48 / 45 MPG
    2010 with 15" = 51 / 49 MPG
    2010 with 17" = 49 / 46 MPG
  17. spwolf
    3,156
    440
    Eastern Europe
    never saw those pics, thanks a lot... as those are run under perfect conditions, there are defintly some differences between modes - keep in mind that during test cycles, cars are driven so they optimize mpg (so they always accelerate at slowest rate possible).
    i think someone wrote some of the eco/power numbers wrongly :).
    is that 3.785 for european tests or?
  18. ken1784
    2,943
    1,374
    67
    Yokohama, JAPAN
    1 gallon = 3.785 liter
    Ken@Japan
  19. hampdenwireless
    hampdenwireless Active Member
    1,104
    86
    Baltimore MD
    Also improving the MPG is improved electronic controller efficiency. I think 5% came from the electronics. Before they needed to be water cooled because with 10,000 watts moving through even a small inefficiency makes heat. Now the electronics are air cooled.
  20. HTMLSpinnr
    5,341
    920
    251
    Um... no.
    New cooling method is "direct" liquid cooling on inverter electronics rather than cooling the heat-sink to which the electronics were mounted on. Hybrid components are still liquid cooled.
