MPG hit with a small trailer?
Discussion in 'Gen 2 Prius Fuel Economy' started by oil_burner, Mar 11, 2017.
  1. Aaron Vitolins
    Aaron Vitolins Senior Member
    1,612
    1,144
    Franklin TN
    here is the prius I bought a few years ago and passed it on to two different siblings of mine. She doesn't die!
    pilotgrrl likes this.
  2. Mikesvagen
    Mikesvagen Member
    31
    31
    Kathleen, GA
    I
    This past weekend took a 300 mile trip, 565 lb camper, 165lb gear, 70lb tongue weight. got 34.1 mpg 2007 Prius w 270k. I did not exceed 65 mph. I was little skeptical but the car handled like champ. There was a strong headwind going out but calm coming home.
    WilDavis, srellim234, jwedel and 3 others like this.
  3. likeitsmylast
    likeitsmylast New Member
    Wanted to sign up on the forum and chime in because I have put some significant miles on my 2008 Prius Touring while pulling a fairly large (for a Prius) trailer. My trailer is a 2017 Sundowner MiniGo 4'x8' enclosed cargo trailer. Empty weight is around 600 lbs. I have loaded it with as much as 800 pounds of cargo, including front-heavy motorcycles. To give you a baseline, my Prius has 146k miles, gets around 40mpg highway when crusing at 70mph, and is stock in almost every way, except a Curt trailer hitch.. I will be having 350lb-rated double-progressive springs installed on Tuesday (yay!), but all previous miles were done on the stock suspension, which was already squeaky/worn out before I started pulling a trailer. The trailer itself is just under 6 feet tall and the front sits a bit higher than the rear due to having to use an upside down drop ball hitch. When pulling the empty trailer, I can get in the 30-32 mpg range at 60-65 mph. Can get closer to the 33-35 mpg mark at 55 mph. But loaded with ~500-800 pounds, my max speed drops significantly and the engine really struggles on minor hills. 55-60 mph tends to be the sweet spot when running heavy. I'll usually get 29-30 mpg, on flat(ish) runs if I keep it below 60 mph. If I bump it up to 65-70mph, I'm lucky to get 25mph and that little gas motor is in pain! It's feels like it's at redline when getting above 70 mph. These trips were 900 miles each way (between Chicago and Dallas). Fairly flat through there, so I can't help with mountain/hilly estimates. Hope this helps someone. From months of research and math, the Gen2 Prius + all-aluminum MiniGo trailer was the best cost/mile I could come up with for my semi-regular trips. But that trailer cost almost as much as the car!! Feel free to hit me up if you have any specific questions.
    Aaron Vitolins likes this.
  4. Aaron Vitolins
    1,612
    1,144
    Franklin TN
    Impressive as well! Would love to see a picture of your towing set up!
  5. Lucifer
    Lucifer Senior Member
    1,014
    485
    Nh
    The OP paid1500$ for an 06 prius, I would so use the 17mpg truck, I would so take a train, Or, I would so make everything fit in the 1500$ Prius, after rubber brakes and a new traction battery.
  6. audiodave
    audiodave Active Member
    783
    268
    US
    Least try pulling the air inlet tube off the air filter box. Engine will breath better.
  7. oil_burner
    oil_burner Active Member
    249
    126
    that inlet is for taking cool air in, so no it will not breathe better
    dolj likes this.
  8. audiodave
    783
    268
    US
    It's taking air from the engine compartment, yes lower than the air box but not exactly cool.
    Try it, you'll hear the engine is louder because of the increased air. Pulling that trailer with 500lbs in the car. Wouldn't hurt.
  9. oil_burner
    249
    126
    its louder because that tube is tuned to reduce a certain frequency. intake modifications usually make no difference in power, if only it were so easy.
    dolj likes this.
  10. audiodave
    783
    268
    US
    Most inlets by the end are smaller than the throttle body. Any performance car or truck that's not the case.
  11. oil_burner
    249
    126
    feel free to prove your theory with a dyno test or 0-60 time, should be simple enough to verify.
    dolj likes this.
  12. audiodave
    783
    268
    US
    70's cars during the big smog years used to choke down the engine with a 1 and a half inch intake on a big block engine. Don't need to Dyno that to know it can't breathe very well. A tuned intake with a smaller inlet will not breath as effective. I tried a cone filter on my Prius with a slightly bigger tube around the mass air sensor. It definitely picked up speed faster. But it's out of range for how it's set up and light up the engine light. Mass air sensor alone set in the smaller than the throttle body tube is a restriction.
  13. PaulDM
    PaulDM Active Member
    616
    317
    UK
    2022 Prius
    Excel
    I lose about 10mpg in my gen4 when towing 725kg
  14. Another
    Another Senior Member
    1,802
    510
    Naples, Florida
    725kg is more than 50% of the Prius curb weight itself! No wonder. Plus weight of driver and passengers
  15. PaulDM
    616
    317
    UK
    2022 Prius
    Excel
    Plus the top box lol
  16. Another
    1,802
    510
    Naples, Florida
    Not to mention, Aunt Edna.
    PaulDM and Mendel Leisk like this.
