MPG indicator while driving is not consistent
Discussion in 'Gen 3 Prius Fuel Economy' started by srdamodaran, Aug 24, 2025.
  1. ASRDogman
    ASRDogman Senior Member
    8,024
    4,072
    You have to replace the rings and pistons. They are the updated ones.
    You probably can't even get the older ones any longer.
    It would cost less money and work and time to get a remanufactured engine.
  2. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Damn, saving gas cost Hell of a lot of
    Money!!!
  3. srdamodaran
    srdamodaran New Member
    17
    Fairfax, VA
    If I had changed the oil at 5K instead of the recommended 10k, and gotten the piston rings for free under warranty, I wouldn't be having these problems...i think.
    ASRDogman likes this.
  4. Mendel Leisk
    42,249
    Another option, especially if cylinder walls are deteriorating, is a new short block. Part cost around $2000~2500 USD. It will have new pistons and rings. It’s the component between upper oil pan and head gasket. Plus labour, maybe a grand?
    I believe this is the part no:
    11400-37140
    (part no determined on Amayama)
    Toyota USA parts site link:
    Short Block Assembly #11400-37140 | Autoparts.toyota.com
  5. srdamodaran
    17
    Fairfax, VA
    I looked at this yesterday and saw some places selling for $1900.
    When I get the diagnostic, I will get them to check the Hybrid battery, the piston rings, HeadGasket, and the cylinder walls. Anything else?
    How do I know if a short block will be good enough or if I need a full replacement engine?
    Thanks.
  6. Mendel Leisk
    42,249
    Yeah I’m also seeing one around $1950 USD.
    Short block is the “heart” of the engine. The next most significant component is the head, everything above head gasket. Machine shop typically provide a refurb service, clean, inspect and replace seals. @The Critic has a head gasket thread on his experience, linked in my signature.
    (on a phone turn it landscape to see signatures)
  7. rjparker
    rjparker Tu Humilde Sirviente
    10,979
    6,885
    Texas Hill Country
    A dealer will not diagnose a weak hybrid battery, they read codes and replace with new if there is a hv battery fail code.
    The excessive oil burning is the rings and a dealer will recommend a new short block and rebuild of everything else or will throw in a salvage engine with no guarantee.
    If you had a head gasket leak now you would know it from the god awful metal to metal start up rattles on occasion.
    Your complaint was mpg.
    You will get a full rebuilt engine with a new short block. They have to pull the engine, tear it apart, rebuild the head and clean up everything else. Most would install new water pumps and thermostat as well.
    On a car this old with 270k miles with issues, most will move on or will choose a lower cost used hv battery and jdm engine. Normally dealers recommend the move on, let's look at our available cars option.
    #27 rjparker, Aug 27, 2025
  8. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    When I did
    Do oil changes
    At Prius meet ups and saw other oils when I drain other priuses, I knew 10,000 mi oil changes were
    Too long of intervals. 5,000 highway miles was the limit. I have 250,000
    Mi on mine, still get 500 to 550 mi to the tank.
