MPG indicator.
Discussion in 'Gen 3 Prius Fuel Economy' started by stpete, Feb 24, 2012.
  1. stpete
    stpete New Member
    Illinois
    Is there a numerical indicator on the dash other than that bar indicator? I know trip A and B have nemericals, but they are not real time ones. Also is there besides trip A or B , lifetime MPG average?
    I remember driving my friend's Prius II and it showed real time numerical MPG's.
  2. ImeanGreen
    ImeanGreen Prius v Five BP Brigade #236
    547
    73
    Somewhere out there
    If you press the trip button a couple of times, after the trip A & B, you should see a screen that says ODO on the lower left. Also when you turn off the car, you will also see your ODO total miles in your dash.
  3. stpete
    stpete New Member
    Illinois
    I know how to check ODO, is there a way to check average MPG for your total miles driven?
  4. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    The Gen II had a lifetime average mpg, the Gen III does not. Some people use Trip B for lifetime and never reset. The only problem with this is if you ever need to disconnect the 12V battery you will lose this number.
  5. fuzzy1
    10,706
    For a real time numeric MPG, get a ScanGauge.
  6. boopie
    boopie Are we there yet?
    47
    Starbucks
    I wondered that myself. So people who are doing display vs calculated MPG comparisons are only doing it for most recent tank or trip?
    For Gen III, is there a lifetime MPG accessible via ScanGuage or ODB or something else?
  7. ryogajyc
    ryogajyc Active Member
    985
    165
    Reseda, CA
    Where is this lifetime average mpg? I have a 2004 and I've never seen this. Perhaps you referring to the average mpg on the MFD? B/c that resets on fill-up, so at best that is average mpg per tank.
  8. fuzzy1
    10,706
    Some are doing that. Some of us are keeping longer term fuel logs (paper, spreadsheet, or online or mobile apps) and computing these outside the car.
    No. To get this, you must keep your own fuel log.
  9. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    You don't see it because it started with the 2006 models.
  10. Codyroo
    Codyroo Senior Member
    1,826
    515
    Pleasanton, Ca
    You will need a scan gauge to get a numerical, instant MPG readout.
    Lifetime MPG can be done by using Trip A or B (your choice) and never resetting after fillups, but will only display the "displayed" lifetime MPG, which is optomistic.
    I track my lifetime mileage with both a spreadsheet and with Fuelly.com. The spreadsheet also allows me to back calculate my displayed lifetime MPG (62.8 mpg) vs my calculated MPG (59.3 mpg).
  11. olyprius
    olyprius Member
    194
    31
    ...or if you get your car serviced with a Toyota dealership that turns off the maintenance reminder but before that accidentally resets your Trip B....(that's what happened to me) :pout:
  12. ImeanGreen
    547
    73
    Somewhere out there
    Sorry. Misunderstood you. In either trip A or B, look at the middle of the bottom screen - cons(fuel comsumption # in MPG). Left to that is total miles since reset. To the right it says ave speed in MPH. Looks like you have to just reset the trip A or B every time you want to know your current MPG.
  13. Tom_06
    Tom_06 Active Member
    609
    142
    Newark, Delaware, USA
    And just like the 2010+ trip MPG indicators, it lasts only until you hit reset or have the 12V battery die.
    Only way to be sure is to keep your own records. And that way you get real MPG and not a calculated one that is high by a couple of MPG.
  14. ryogajyc
    985
    165
    Reseda, CA
    Ah, that explains it. For clarity, then...
  15. fuzzy1
    10,706
    ... and to me, when visiting a different shop during a road trip.
    Also, I reset one trip meter daily, and the other when refueling. For some reason, I must accidentally clear the wrong meter at least once per year. So the paper log is necessary to retain the bulk of the car's history.
  16. stpete
    stpete New Member
    Illinois
    Not to whine or nothing, but with all computers on board ,it should have lifetime MPG thing as well as digital readout for MPG, just saying. Prius prouds itself on fuel economy and those two things should be emphasized for owners and others to see.
