MPG is improving
Discussion in 'Gen 3 Prius Fuel Economy' started by james nancy, Aug 10, 2021.
  1. james nancy
    james nancy Member
    110
    24
    suva,fiji
    Yes, frequent short trips and the engine is often in the warming stage will reduce fuel consumption performance. Before the test, the journey is basically guaranteed to be more than 10km, so that the mpg is in a high state. It will decrease during normal driving. I will continue to report on the changes of MPG.
  2. Abarnabe
    Abarnabe Active Member
    168
    100
    Netherlands
    Ambient temperature and humidity have a big influence on the prius, bigger than non hybrid cars. If you live in a warm country you will enjoy the prius efficency at the top of its capabilities
  3. james nancy
    james nancy Member
    110
    24
    suva,fiji
    Yes, I'm warm here and the temperature doesn't change much, which does have a positive effect on the engine and the hybrid system. The prius is a good car. The current state is that it has the capacity it should have. The fuel consumption is better than before the high-voltage battery was replaced. It used to be the highest at 28km/l.But driving was much more conservative back then,
    I feel like it can now reach higher fuel consumption levels if very careful
    #43 james nancy, Jan 26, 2022
