MPG is no longer being calculated
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by invertere, Dec 25, 2014.
  1. invertere
    invertere New Member
    2014 Prius c
    I just noticed a few days ago that my 2014 Prius C is no longer calculating my MPG. It is stuck on 44.5mpg even when I first turn my car on. It never changes. Has anyone else experienced this issue? Would it be covered by any sort of warranty?
  2. hieronymous
    hieronymous Member
    154
    92
    Auckland, New Zealand
    2013 Prius Plug-in
    Are you sure you are not looking at your tank average, instead of your trip average? Your tank average will settle to a near-constant value as the tank gets nearer to empty.
  3. invertere
    2014 Prius c
    Hmm, I didn't know there was this option. Where do I find each one to figure out what one I'm on? It normally changed based on how I drove, so either I accidentally hit something and it got switched, or it stopped working. I have the display set to the eco score screen and the MPG was displayed right next to the miles. It's not my image, but the display is this one:
  4. hieronymous
    hieronymous Member
    154
    92
    2013 Prius Plug-in
    Your picture shows Trip A. On your steering wheel you have a Trip switch which cycles between ODO, Trip A and Trip B. If you hold the Trip switch down for Trip A or Trip B it will zero that fuel economy setting - you would do this, say, only when you fill up for Trip A, and each morning for Trip B for your commute. So Trip A would give you your tank average, and Trip B your daily round trip average. Somehow you have set one or both of these.
  5. invertere
    2014 Prius c
    Ahh, ok thanks! I had no clue there was this option.
  6. Easy Rider 2
    Easy Rider 2 Senior Member
    1,584
    258
    Ocala, FL
    I'm not sure the previous answer was clear.
    When your display is showing the ODO.....your total miles.....then the MPG figure beside that gets reset every time the engine is turned off.
    The separate figure for trip A and trip B gets reset along with the trip mileage.
    I use trip A for my "tank" mileage and B for long term average.......except when the wife fills up and resets EVERYTHING. :mad:
  7. bisco
    52,785
    funny, i think another c owner posted the same thing awhile back.:)
  8. robertmaria
    robertmaria Member
    202
    please DELETE this account
    2014 Prius c
    be careful holding down Trip if itz just the ODO odometer. it will jump to kph instead of miles per hour. to avoid that mistake is why i usually leave it on trip B now.
    if you do go to kph, just go back to ODO and hold it down again to go back to miles per hour. no need to panic.
  9. Oldwolf
    Oldwolf Prius Enthusiast
    826
    110
    NC
    2016 Prius v wagon
    I use Trip A for each tank and Trip B for each oil change.
