MPG Jump?
Discussion in 'Prius c Main Forum' started by orangenerd, May 9, 2012.
  1. orangenerd
    orangenerd Junior Member
    58
    Lawton
    So I have about 1700 miles on my Prius C...been averaging about 50 mpg overall...normally it shows 50-55 mpg by the time I get to work. BUT since my last trip to the pump 150 miles ago I have been getting a ridiculous 65-75 mpg average... I have not changed my route or driving techniques... I can only think of a few reasons.
    1. The gauge is off. ( hopefully not)
    2. The engine has finally broken in (took a little long though, dontcha think?)
    3. I increased the Tire Pressure to 38/40 psi. (It can't really increase MPG that much can it?)
    4. The weather is getting warmer. (I live in Oklahoma, the weather gets hot BUT it hasn't gotten really hot yet)
    I am truly perplexed. Help me out fellow Prius owners.
  2. PriusCinBlack
    PriusCinBlack Member
    145
    61
    Probably a combination of all 2, 3 and 4, plus you're probably getting better with using the techniques, if you're using any at all, whether your realize it or not. Just practice, even if it doesn't seem to you you're getting any better at it.
  3. dano9258
    dano9258 New Member
    59
    Las Vegas, NV
    Does increasing tire pressure help that much?
  4. HaveNoCents
    HaveNoCents Conservative Tree Hugger
    299
    46
    Crystal Beach, Texas
    Yes. When I was at factory specs I was getting 45. I changed to 40/38 and I started seeing 50 calculated. Now I changed to 42/40 and got my best calculated since I bought the car. 55mpg.
    Most of my trips are under 10 miles. I have a 150 mile trip every two weeks.
  5. dig4dirt
    dig4dirt MoonGlow
    1,150
    741
    Lancaster Co PA
    2014 Prius c
    combo knockout!
    I would say all too (except gauge)
    Warm vrs cold plays a big role.
    it is about 25% jump or better, but add in about 2-5mpg for each thing and you get close.
    Good Job!
  6. scudmonster
    scudmonster New Member
    31
    Arkansas
    "I increased the Tire Pressure to 38/40 psi."
    What exactly does that mean? Is the first number for the front tires and the second number for the back tires?
  7. HaveNoCents
    299
    46
  8. XRinger
    XRinger Member
    201
    47
    Woburn, MA
    Wow, that's an interesting problem. I've heard of people getting some high MPGs with the Prius C, but I think they weren't unexpected.
    You should do some manual MPG calculations, and let us know what you find..
    You've got my interest!
    Cheers,
    Rich
  9. SquallLHeart
    SquallLHeart The Techie Guy
    826
    247
    San Jose, CA
    yes... it's probably a combination of factors..
    also, as the weather gets warmer... the summer blends of fuel are going to start getting placed in gas stations... and they yield better mpgs compared to the winter blend.
  10. dig4dirt
    dig4dirt MoonGlow
    1,150
    741
    Lancaster Co PA
    2014 Prius c
    I also been reading up on this ethanol.
    Maybe you slipped in some pure gas?
    Any change on fuel pump or station?
    Go for pure if you can
    I will be starting in both my Prius'
  11. scudmonster
    31
    Arkansas
    I see several differing ideas about the best tire pressure. What is the most recommended for great MPG?
  12. south central
    south central Member
    100
    south central Illinois
    Humm, I figure Toyota did all the research and they would want the highest mpg, to be reported by the customer, for the c's bragging rights.
    The recommended tire pressure (for best mpg? well, you be the judge) is posted on the driver's side B pillar. The number stamped on the tire is the max psi for that particular tire.
    Deb
  13. secondspassed
    secondspassed Member
    112
    26
    Corona, CA
    I find 40/38 to be quite comfortable, for what it's worth. Not too stiff.
  14. F8L
    19,011
    4,080
    50
    Grass Valley, CA.
    Like the others have stated, it is a combination of many things but warmer weather is usually the largest contributor to mpg differences not counting driving style. With temps of 70F or higher Prius efficiency goes way up. For those of us with an early morning commute this is very obvious. During winter, morning commute temps may be in the 30s or 40s and I struggle to get 46mpg. In summer when temps are 60F+, I can get 50mpg. The difference is less noticeable on the way home because temps are usually 60F+.
    Our weather recently started hitting the high 80s to mid 90s and my mpg shot way up. Combined with careful driving I am sitting at 58.8mpg over the last 260miles. I was at 59.4 but high winds drug it down.
  15. GraeSack
    GraeSack New Member
    30
    Lacey, WA
    I run my Pc3 tires at 40F/38R. On informal A-B test I went from 56.1 to 60.4 with the increased pressures per the display. This was on a mixed suburban/freeway loop. I need to do a more rigorous test.
    All the best.
