MPG... Just mentally reduce what's displayed by 10%?
Discussion in 'Gen 4 Prius Fuel Economy' started by dslomer64, Jan 8, 2017.
  1. Mendel Leisk
    42,364
    I always refill when it's at the halfway mark. For several reasons. One being security. The other: I want to be the one refilling, recording the odo and trip meter info. The odometer reading in particular is good in that regard: never gets reset; if things go pear-shaped at one fill up, as long as you have the gas receipt, of volume pumped, you can lump it in with the next tank.
  2. greenmonster01
    106
    79
    Southeastern MA
    There's an app for that ;)
    I use gascubby on my iphone and fuelly on the web... I need to upgrade to ios 10 so gascubby will sync with fuelly.
  3. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    I mean the difference between the mileage the car says you get to the gallon and your calculated mpg. :rolleyes:
  4. Mendel Leisk
    42,364
    If our dash says 4.7 liters/100 km, for example, calculated will be 5.0 or 5.1.
  5. Chippingawayatlife
    Chippingawayatlife Active Member
    159
    116
    San jose
    Mine is also 7% optimistic. This seems regardless of if I'm driving light or heavy through mountains with 4 passengers. It kind of bugs me now when I hear people in the media reporting mpgs without stating if it was the dashboard or calculated.
    RCO likes this.
  6. Mendel Leisk
    42,364
    Yeah it's like knowing a compulsive liar. Sad though: Toyota's the mpg leader, why not play it straight? o_O
    RCO likes this.
  7. RCE1
    RCE1 Member
    70
    71
    Northern California
    Four Touring
    Mine's +/-5%. I usually use the computer estimation for telling my friends how awesome the car is ;-}
  8. fuzzy1
    10,720
    No, because the fuel economy meter is based on the odometer, not speedometer. Odometers don't have that same built-in error. At least, not anymore in the U.S., ever since the class action product liability lawyers worked over the car makers for warranty fraud.
    Long ago, many of us noted that the internal computers know the speed quite accurately, and report such to the various aftermarket OBDII engine monitors (ScanGauge, Torq, and many others). The error the driver sees appears to be added right at the dashboard display, and doesn't come through on that monitor port.
    dslomer64, RCO and Mendel Leisk like this.
  9. BruceInOKC
    BruceInOKC Member
    190
    Oklahoma City, OK
    Ha, I like it!
    RCO likes this.
  10. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    I had a friend in the car the other day who is "not PRIUS friendly" - he was quite taken aback when, as I started up, I flicked the screen to read instead of the hybrid monitor:
    I think he almost choked when he saw the figures - he didn't comment - so I didn't have to say that it's not always that good.
    RCO and Prodigyplace like this.
  11. at100plus
    at100plus Junior Member
    Ok this might answer the question I just posted over in the Gen II Custom PIDS for Torque thread. I've had my Gen2 for about a month and my Torque App AVG MPG is usually about 7 mpg lower than my on board display on my 40 mile commute. IE today I saw 56 mph on my on board and 48 mpg on Torque but the instant MPG is about the same on both.
  12. Prodigyplace
    12,720
    11,852
    Central Virginia
    People are comparing fuel added & odometer readings to determine accuracy. I do not know where Torque accuracy fits into that.
  13. greenmonster01
    106
    79
    Southeastern MA
    This tank the difference was 3.75%, so I guess it moves around a bit. Only 2.8 mpg difference this past tank. I'll have to keep track to see how much it changes from tank to tank. I've only checked sporadically up until now.
  14. Prius from Dad
    Prius from Dad Senior Member
    724
    1,116
    Toms River, NJ USA
    I tracked the difference on my 2012 v and after 241 fill ups there was a difference of 5.3%. In my Prime the difference, after 7 fill ups, is 5.5%. Seems to be consistent between Toyota Hybrid models.
    RCO likes this.
  15. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    With consistent filling to the second click on the pump every time, mine seems to be consistently around 4 to 4.5 mpg optimistic, which is between 7 and 8% out
    Mendel Leisk and RCO like this.
  16. dslomer64
    dslomer64 Member
    157
    Cincinnati, OH
    Me, too.
    Gen 2 (2006) and Gen 4 (2017)
  17. Chippingawayatlife
    159
    116
    San jose
    Reading some articles online (Google gas top off) tells me that fuel used after the first click is siphoned back to the gas station and therefore a waste. I'm not sure if this is true but perhaps if you tried not going past the first click for the next few tanks, you can check if you 7% decreases. I'm usually getting around 5% difference.
    Prius from Dad likes this.
  18. dslomer64
    dslomer64 Member
    157
    Cincinnati, OH
    Hmmmmm..... Gonna check that out!
  19. dslomer64
    dslomer64 Member
    157
    Cincinnati, OH
    "'When we overfill the tank, it sends all of the excessive fuel to the evaporation/charcoal canister and kills the life of that canister,' said Joel Carruso of Caruso’s Auto Repair in New York.
    "Topping off ... can cause pressure to build in the tank and flood the carbon filter vapor collection system.... Subsequently this ... can affect your car’s performance and could possibly damage the engine."
    That's from
    Why you should never ‘top off’ your gas tank | Clark Howard
    Word to live by, though, huh? But look:
    "According to the EPA, once a gas tank is full there is no way to fit any more gas in the tank. Gas stations are equipped with a vapor recovery system so that if a tank is full, the pump will pull the extra gas you’re trying to pump into your car back into the station’s tanks. This is a safety precaution to ensure excess vapors will not escape into the environment."
    Another source: Why You Shouldn’t Top Off Your Gas Tank | Louetta Automotive | First Class Service
    "When you fuel up, the gas pump automatically shuts off once it fills your gas tank."
    No. No way. I've had click-off FAR before tank was full.
    "...the fuel you pump while topping off can be forced back into the gas station’s pump."
    I think we need a definition of "topping off".
    "I do tend to top off ... and my experience suggests to me that I do indeed get more gasoline into the car ..."
    Me too.
    Then there's this from
    http://thegate.boardingarea.com/three-reasons-why-you-should-not-top-off-the-fuel-tank-of-your-car
    "When the gas pump automatically shuts off, a vapor lock blocks more gas from entering your car."
    Aha? No. But ... Isn't this guy contradicting himself?
    "After the tank is full, the gas you pump gets sucked back through an outer 'vapor-return' hose into the station’s underground storage..."
    Maybe we need a definition of "full".
    "The nozzle is able to determine when the tank is sufficiently full and shuts off the flow... It is possible to add more gas (so the tank is NOT FULL!) after this point.."
    Nah. ... ?
    This is frustrating. Hour of research and a bunch of (interesting!) contradictions.
    Are these guys politicians or lawyers?
    https://www.google.com/amp/amp.automoblog.net/2011/08/15/topping-off-learn-why-you-should-never-top-off-your-gas-tank/ says:
    "Once you hear the first click of the gas pump, did you know any gas you pump after that isn't going into your car’s tank?"
    It isn't? Well why didn't you say so? I'm going to quit doing it!
    Look. Just don't top off, like it says on every pump, for all the right reasons: environmental, safety, repair.
    #39 dslomer64, Jul 2, 2017
  20. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    IMHO, at the first click the tank is nearly full but frothing in the fuel is still releasing a volume of vapours. Once this settles out, the level of fuel in the tank has fallen slightly, allowing more liquid to enter before triggering the tank full reaction again. The rest is arguably speculative at best and masculin bovine excrement at worst.
    dslomer64 and kithmo like this.
