MPG question
Discussion in 'Gen 3 Prius Technical Discussion' started by defrankond, Aug 30, 2014.
  1. defrankond
    defrankond Member
    217
    23
    North Dakota
    i have noticed that my mpg's usually have sweet spots. i am sure that my prius g3 series 5 is heavier than others but at lower speeds below 35 i usually get crappy mpg unless on ev. but anything above that up to 75mph i usually get around 50mpg. is this normal? 736xx miles on the clock.
  2. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    When going slowly enough with the engine running you are "wasting" some fuel (because you are not using enough power to overcome the waste that is always there) so mileage drops with speed below about 35. Prius (and many other cars) gets its' best mileage at around 35 to 45 MPH, and maybe even a bit higher. Above about 55 MPH air drag becomes high enough to start to drop mileage. Air drag increases faster than speed so it really begins to dominate above 65 MPH. This is why Prius gets better city mileage than highway mileage.
    But, sometimes all this gets messed up. Which is why YMMV. ;)
  3. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    One of the ways that Toyota gets good mileage is that they put in a very low horsepower engine.
    Most engines are wildly over sized, and spend a great deal of their cruising speeds at almost idle, with the throttle plate only slightly cracked open. The cylinders are trying to pull in air but are unable to because the throttle is almost closed, this is called 'pumping loss' as it is an inefficient way to pump air. (You can also get high speed pumping losses when the intake manifold is not large enough to flow all the air the cylinders attempt to pull in)
    By having a lower HorsePower engine, the throttle stay open more often and cruising is not near idle. Obviously, if you go slow enough, even the wimpy Prius engine starts having pumping loss. Under those situations, the computers may use EV to avoid light loads, alternately it may stay in a gas mode, but charge the battery to provide enough demand to avoid pumping loss. If the battery is already charged, EV is the choice.
    I find this to be below 37 MPH in my v.
    #3 JimboPalmer, Aug 30, 2014
