MPG reading appears way off??
Discussion in 'Gen 5 Prius Main Forum' started by Jamie 254, Feb 20, 2025.
  1. Jamie 254
    Jamie 254 New Member
    New Hampshire
    2024 Prius
    Limited AWD-e
    New 2024 Limited AWD. At recent gas fill up, reset the MPG with the OK button and got it back to 0.0. Filled with gas as much as possible. Drove 185 miles, filled gas this time to just about overflowing. Car claimed MPG of only 39mpg. Very disappointed, as was all highway miles, ECO mode and thought I was driving conservatively, even keeping at 68-70mph. But, only took 3.8 gallons, and my math says 48.7 MPG.
    So which to believe? Anyone else have that issue? Thanks
  2. MAX2
    MAX2 Senior Member
    1,436
    490
    101
    Third planet from the Sun
    It is difficult to judge by one result.
    You need to accumulate statistics.
    Any measuring instrument can have an error, including a trip meter, a meter on the dashboard or a meter on a gas station pump.
  3. FuelMiser
    FuelMiser Senior Member
    1,349
    929
    Monument, CO
    If I were you, I would not "fill with gas as much as possible" You risk triggering the Check Engine Light for fuel vapor capture issue. Let the pump click off and stop there.
    schja01, Winston Smith and Xse like this.
  4. CooCooCaChoo
    CooCooCaChoo Senior Member
    962
    544
    Cow-lee-fornia
    2023 Prius
    Well, first thing you need to do is stop pumping gas after it clicks off. You risk damage to the EVAP system by continuing to force gas into the tank. Secondly, it takes effort to get good mileage out of the Prius. You can't just drive with a lead foot all the time and expect great fuel economy.
    If you want to keep track of your fuel economy, use Fuelly.com.
    Winston Smith likes this.
  5. Jamie 254
    New Hampshire
    2024 Prius
    Limited AWD-e
  6. Xse
    Xse Member
    76
    34
    Brighton Ontario Canada
    2024 Prius Prime
    XSE Premium
    What fuelmiser and coocoocachoo said about stop pumping gas after it clicks
    It’s going to cost you big
  7. frodoz737
    frodoz737 Top Wrench
    4,798
    2,560
    33
    I've topped off both Prii and the RAV4 HV since day one with no problems. In fact...I have done this with every vehicle I've owned since HS and I'm 66 now...and a career mechanic.
    Blackat likes this.
  8. Winston Smith
    Winston Smith Active Member
    456
    330
    OH
    2024 Prius
    LE AWD-e
    It is unlikely that the tank is filled to precisely the same level each time, so filling after consuming only a few gallons will amplify error in the gallons part of your measurement. You can probably get almost a gallon into the tank and gas evaporation system after the pump first clicks. That will ultimately damage that system and may cause it to fail environmental checks in regions that have that.
    If the engine isn't broken in and you are driving in NH in February that also won't be great for efficiency.
    My car typically estimates about a mile per gallon, or about 2%, more than refill calculation indicates.
  9. Jamie 254
    New Hampshire
    2024 Prius
    Limited AWD-e
    Thanks; I did it also most times with my 2007 Prius, and never had a problem over 18 years. Maybe just lucky?? Found too many times the gas pumps shut off when there's still 1+ gallons left to go...
  10. Blackat
    Blackat Active Member
    486
    355
    Colorado
    2023 Prius
    Limited AWD-e
    I've also put the max amount of gas in the tank for the last 18 months with no problems.
  11. Winston Smith
    456
    330
    OH
    2024 Prius
    LE AWD-e
    My understanding is that there is an evaporative emissions system in all modern cars with gasoline engines that routes vapor from the filler neck to a charcoal cannister.
    When impoverished student Winston sees gas for $1.10 when it's $1.45 everywhere else and clicks the nozzle until he can see gasoline in the filler neck, he ends up dumping liquid gasoline into the charcoal cannister. When that happens enough, the evaporative emissions system stops working and you can have problems with passing emissions testing.
    That understanding of mine may go back to Click&Clack episodes.
    Xse likes this.
  12. Mendel Leisk
    42,314
  13. Hammersmith
    Hammersmith Senior Member
    2,476
    2,535
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Correct.
    Also, liquid gasoline in the evap canister ruins it. And there are two other valves that are part of the system that can be ruined if the canister gets filled with liquid. There's a vent valve that allows fresh air into the system that is supposed to only allow air in one direction, but can get stuck open if charcoal particles get stuck to it when they are carried by liquid fuel. This will result in gas vapor escaping the vehicle into your garage, house, whatever. There's also the evap purge valve that releases the collected fuel vapor into the engine to burn it off. If that valve fails, you'll get a check engine light and the car might stall out.
    The charcoal canisters are often very expensive, and some are placed in terrible locations that means you have to tear apart a good chunk of the car to get at them. I've heard of cases where the rear subframe, exhaust, differential, etc. had to be dropped to get at the canister. In the gen5, the repair manual says the exhaust has to come down. And the MSRP for the charcoal canister is $680. So to have it replaced at a shop would probably run you $1000-$1500 depending on whether the vent and purge valves are involved. You could do the job yourself for as low as $375(max discount on canister and no labor), but that's still $375 down the drain for what benefit? Is that extra half gallon in the tank really that important?
    Here's a video from TheCarCareNut on the topic. It's one of his earliest videos, so the production quality and his delivery are way below his current standard. Still, it explains everything(including basic diagrams) and it's from someone with real experience and not a Joe Blow like me.
    MAX2 and SkiLodge like this.
  14. Gokhan
    Gokhan Senior Member
    6,712
    2,661
    Paramount CA
    Probably you should believe neither. However, people claim that the Gen 5 mpg gauge is accurate unlike Gen 4’s, the latter of which overestimates by 5 mpg.
    4 gallons is not enough for an accurate mpg estimate. You should aim for 9 gallons or more next time.
    Also, the car needs to be on a slight downward slope when you fill up; otherwise, it will take 1–2 gallons less than the rated capacity. This is probably what happened, and you were shy about 1 gallon from a full tank, which works out to exactly 39 mpg as on the gauge.
  15. Mendel Leisk
    42,314
    Presumably for a more accurate fill?
    Considering the possible detrimental effects to your evap system, and just to expedite fill-ups (especially when there's someone behind you, drumming their fingers), it's simpler to just pump, back off a little when it approaches full, and then stop, when the auto-shut-off first activates. This'll be approximately the same from fill-to-fill, and while there might be slight differences, it all balances out.
    #15 Mendel Leisk, Feb 21, 2025
    MAX2 and Gokhan like this.
  16. RandyPete
    RandyPete Active Member
    409
    171
    Santa Margarita, CA, USA
    2024 Prius Prime
    XSE
    Was your previous car a limited AWD model equivalent ?
  17. Jamie 254
    New Hampshire
    2024 Prius
    Limited AWD-e
    No, previous car was 2007 Prius, FWD; had for 18 years. Consistently got 44 mpg in winter, 48 in summer.....
  18. RandyPete
    409
    171
    2024 Prius Prime
    XSE
    You should expect an AWD car to get less miles/gallon.
