MPG "The Perfect Method"
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Andyprius # 1, Jun 28, 2012.
  1. JamesCSmith
    JamesCSmith New Member
    59
    I agree. It seems like an accounting trick that makes certain stats look better but isn't truly more efficient.
  2. Coyotefred
    Coyotefred Member
    132
    31
    Western Nebraska
  3. Post # 1 is not accounting trick, it is a fact. I am only referring to trips, 100-200 miles minimum. Commuting 15 miles every day with numerous wall charge opportunities do not apply to stacking.
  4. drinnovation
    drinnovation EREV for EVER!
    2,027
    586
    65
    CO
    That is using the ICE to indirectly charge, if regen happens on the downhills, the ICE provided power to clime which regen then put into the battery. That is an example of an accounting trick.
    Being a fact does not mean its not an accounting trick. The real question is does this actually improve efficiency or its it just shifting data around (in terms of EV/HV miles) while being about as efficient as normal driving. As someone that looked at MM games in the Volt, I'm used to trying to figure out what is real efficiency and what is just apparent gains. 91MPG over 131 miles is good, but it was also effectively down hill. I posted earlier the overall MPG number might work out with this just being an accounting trick. It might also be a real efficiency gain, we just don't have enough data to reach a meaningful conclusion.
    I also note you never explained the discrepancy with the first post saying you only did this technique for 20 miles.
  5. To clarify, it is my habit to run in EV on every downhill roll and to simultaneously recharge when possible. The last 20 miles is called the foothills of the Sierra Nevada, this is where I was far more aware of the procedure and that I pulled into my garage with about 10 miles left on EV , I do not consider this a faux pas. Use it today or use it tomorrow makes no difference. As you say, it is not possible to measure efficiency from our perspective. But we can definitely note the mpg of the trip and that is a pretty good guide. Good enough for me anyway. Yes it was all effectively downhill, that is when the opportunity presents itself. I definitely couldn't do this at Bonneville.
  6. Corwyn
    Corwyn Energy Curmudgeon
    2,171
    659
    23
    Maine
    Yes, you did. Going down hills and charging the battery gets its energy from the gas you used to get up the hill in the first place. Anything after the 5.5 kWh you got from dropping 4500 feet, came indirectly from the gas tank.
  7. I would put that statement in the same category as the chicken and the egg, or, the tree in the forest. It is all theoretical nonsense. The real facts are available to us on our Mfds in the form of MPG over X distance. Anything else just clouds the issue. Is that your intent? Now should you replicate my stats from Post #1 with your own methodology, I would be most interested in listening.
  8. CharlesH
    2,798
    1,166
    Roseville, CA
    I would agree that mpg over distance + net kwh from the wall used is a reasonable metric. Basically, how much gasoline was used, and how much electricity from the grid was used.
    If this was clarified in some intermediate post, I'm sorry I missed it, but are you saying that you traveled 137 miles round trip between Sacramento and Tahoe, and the display indicates that you got 91mpg with essentially no net electricity consumption (assuming you started "full", ended almost "full", and didn't plug in any time during the trip)?
    I just can't get my mind around how the technique of HV up hills, EV down hills and flats, can possibly have any significant effect on overall fuel (gasoline+electricity) consumption.
  9. Sorry for the imprecise ness , I tanked up in Carson City, zero'd out on trip A, drove up a fairly modest mountain ( Rt 50 ) to S Lake Tahoe. While there I wall charged the car a few times at the Hotel Garage. On the day we headed back, I wall charged again. On all descents I charged and also drove In EV on modest flats. Within 5-8 miles of home there is a series of mild undulating hills and I was able to continue the same technique. Hopefully this clarifies things. This was one way, and only one leg of my three legged trip. Cheers.
    CharlesH likes this.
  10. Very true, BUT, my intent was to conserve EV. ( going uphill )
  11. Corwyn
    2,171
    659
    23
    Maine
    I don't think being rude is going to allow you to break the laws of physics, even if they are 'theoretical'. Give up on your vision of your 'perfect method' and you might be able to learn something from all the experienced people on PriusChat.
  12. ukr2
    ukr2 Senior Member
    1,020
    278
    31
    Victor, NY
    Bielinsk,
    If the ICE is already up to temp, when it switches to HV, it will use no battery.
    Switching to HV with a cold ICE will use up battery until the ICE is up to temp.
    So if you're planning to exceed 62 mpg on a highway, it's best to manually switch to HV or just step on the Gas while in EV to get the ICE to start on a flat road a mile or so before getting to the highway.
    Andyprius # 1 likes this.
  13. devprius
    devprius /dev/geek
    979
    291
    San Francisco Bay Area, CA
    Of course you are going to get great gas mileage coming home from the Reno/Tahoe area. It's mostly downhill with little need to use the gas engine. And you've started out with a full EV charge. I'd be more interested to know what your MPG was for the whole trip. I'm sure your gas mileage sucked mightily going up 80...
  14. ukr2
    ukr2 Senior Member
    1,020
    278
    31
    Victor, NY
    Andy,
    As others have stated, you are wasting gas. Since Electric miles are cheaper and cleaner than Gas miles, use the battery charge when you want, but you should Totally Discharge the battery before getting home or any other location that allows you to Recharge. If you get home with any battery left, you are using more Gas and getting lower MPG.
    drinnovation likes this.
  15. Thankyou for your reply Ken. However, as I and others have experienced, if all of the EV is used, further EV charge is not possible, aside from 1-3 tenths and the car is stuck in HV mode. No radical EV charge is possible and we are back to Generations 1,2 and 3. The truly revolutionary aspect of the Pip is that with intelligent energy management it is possible to run the the car thousands of miles on mostly EV mode. That may be a stretch. Of course it all depends on terrain and most of all, " The Driver "
  16. ukr2
    ukr2 Senior Member
    1,020
    278
    31
    Victor, NY
    Andy,
    You don't have to use all your battery right away.
    Put the PIP in HV as much as you want, but get it back to EV and use up the battery before you get home.
  17. Yes, I definitely go along with that. It is just difficult to predict.
  18. bisco
    52,819
    the worst thing is when you are on an unknown route, you're near home, but you use up your ev a little too soon.
  19. devprius
    devprius /dev/geek
    979
    291
    This is pretty much counter to what I have experienced. I get 1.5 to 2.1 miles of EV back at the end of my commute when going home. The car will automatically switch from HV mode back into EV mode at 1.5 miles. It is possible, with a big enough downhill, to almost fully recharge the battery just from regen. What you describes sound more like the 2010 test cars which didn't have the ability to recharge EV via regen.
  20. ukr2
    ukr2 Senior Member
    1,020
    278
    31
    Victor, NY
    That's not a problem.
    When you use up the battery and it switches to HV, there is still battery available.
    When in HV and you keep the energy bar to the left of the center line, it has the ICE off and is using battery.
    The more battery you use, the less gas you waste.
