Mpg to fill up
Discussion in 'Prime Main Forum (2017-2022)' started by priuscatprimeguy, Mar 31, 2017.
  1. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
    First fill up since dealer put gas in on November 30, 2016
    1666.4 miles as of March 30, 2017 Dash reading of MPG 182.4
    Calculated MPG ( well I topped off so my bill would be an even $20.00)
    $2.069/gal with 9.666 gallons 172.399 MPG
    My trip to and from Fort Wayne Indiana 405. 6 miles 58.1 MPG
    52,871
    i'm at 2,600 miles since filling up 10/27/16.
    ruby, Prius from Dad and giora like this.
  3. priuscatprimeguy
    2,730
    2,640
    nobody likes a show off (unless it's me:p)
  4. drysider
    drysider Active Member
    823
    337
    Liberty Lake WA
    Sounds like stale gas could become an issue...one I wish I had.
  5. priuscatprimeguy
    2,730
    2,640
    the owners manual says one year between fill ups
    drysider likes this.
  6. bisco
    52,871
    that's excellent, the pip is only 6 months. i have to fill up by april 27.
  7. Sandollars
    Sandollars Prius Maven
    134
    157
    SoCal
    Wow! These are great numbers!
  8. bwilson4web
    16,546
    It is important that we use www.fueleconomy.gov to document our mileage, the "My MPG" log:
    The last tank tested the use of CHARGE mode when running the tank dry.
    Toyota4Life likes this.
  9. davidtm
    davidtm Member
    180
    TJ'ville
    I wonder if it's worth buying ethanol-free gas for this reason?
    Tab4 on Tapatalk
  10. priuscatprimeguy
    2,730
    2,640
  11. FuelMiser
    FuelMiser Senior Member
    1,349
    929
    Monument, CO
    I'm pretty sure "topping off" is not recommended in modern cars with fuel vapor recovery systems ...
  12. ed4271
    ed4271 Member
    107
    64
    US
    Yes it will help for longer storage, less water build up. Better for the engine. Also when
    fueling up use a gas station that meets Top Tier standards engine cleaning detergent additives. Non Top Tier gasoline causes 19 times more deposit then top gear brands after 4000 miles. Such carbon deposits are known to reduce fuel economy and will have a negative impact, particularly on newer vehicles. To find top tier gasoline stations go to 404 - Page Not Found | TopTier Palletizers
  13. priuscatprimeguy
    2,730
    2,640
  14. priuscatprimeguy
    2,730
    2,640
    3883.1 miles since fill up 6/28/2017:p
    and I saved $1.00/gal at Kroger $1.41 Gal:D
    bisco, huskers and joachimz like this.
  15. bisco
    52,871
    i'm just starting a new tank, not sure of the miles. i'll check later and fill in. at 11.4 miles estimate, i'm getting engine warmup on some of my regular trips.:mad:
    priuscatprimeguy likes this.
  16. Mendel Leisk
    42,358
    Paying with plastic?
  17. priuscatprimeguy
    2,730
    2,640
    yup, but this time I stopped at the first click:D
  18. EarthPIG_0311
    EarthPIG_0311 Junior Member
    The 951
    Most efficient tank - 766.9 miles/8.47 gallons = 90.5mpg. This is also the most miles I've driven on a single tank. I tend to fill up at the 1/4 tank mark. Love this car, I've had it for just over a month (11/9). 55 mile one way commute plus possibly losing the fed tax credit made me pull the trigger sooner than I wanted but it's a great car.
  19. priuscatprimeguy
    2,730
    2,640
    well, so far I've travelled 11,635.0 miles. And spent $439.72 total on gas and electricity ($15.00/ mo as per landlord agreement) so 11,635.0 miles/ $439.72 = $26.46 average cost. going further if you take 8 gallons of gas, divide that by $26.46 you get $3.3075 per gallon.
  20. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    Better work a bit harder on that math.
    fuzzy1 likes this.
