MPG under Short Distances
Discussion in 'Newbie Forum' started by boricua, Dec 20, 2015.
Tags:
  1. boricua
    boricua New Member
    florida
    New Prius buyer, hopefully within 3 weeks or so, not sure if regular or V type.
    I really like the Prius for the high MPG record but saw a post about the MPG not being as effective for trips under 5 miles, is this true?
    I understand the V gives less MPG than the regular Prius but the short distance is what I am most curious about?
    Thank you.
    52,843
    correct. it maybe less than 5 miles in warm area's like florida. it's because it has to go through the warm up cycle the first few miles. the colder the climate, the more gas gets burned until the unit reaches operating temp. and if you have the heat on, that raises the max temp it has to reach.
    when you test drive it, reset the trip meter and watch the average mpg's climb, the longer you drive.
    the good news is that all gas cars suffer from this, and the prius is still the most efficient, even for short trips. of course, once it's warm, multiple short trips suffer less.
    ideally, if you only commute a few miles, you're better off with a plug in hybrid, or electric car.
    yes, the v is larger, and the mpg's are slightly lower than the lift back.
  3. boricua
    boricua New Member
    florida
    Hi Bisco and All,
    My driving pattern every other eek changes quite a bit.
    One week I drive maybe 60 miles of short distances from 5 to 15 miles and the following week I drive around 125 miles.
    You think a Prius plug in /hybrid would work best since for the short drives full electric mode would be the primary source?
    52,843
    depending on you acceleration and speed, the pip can get you 10-15 miles each time after you plug in, and gets better mpg than the non plug in when you need the engine. if you can plan your trips accordingly, it maybe a good vehicle for you, and i have heard they are very reasonable in florida.
  5. boricua
    boricua New Member
    florida
    very helpful, thank you!
  6. bisco
    52,843
    pleasure, all the best!(y)
    boricua likes this.
  7. lifehouse
    lifehouse Junior Member
    92
    GA
    Welcome to the club mate, sounds pretty normal to me too for V's!
    boricua likes this.
  8. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
    ...I hear the v is good at warming-up more quickly (better than Gen2 or 3). Right now on our Gen2 our MPG is down as we stopped our work commutes and now mostly shorter trips. I am thinking we might be able to shift to v and not see too much MPG hit, assuming v is better MPG cold than a Gen2.
    I assume the Gen4 (2016) Prius will be as good or better than v when cold.
    boricua likes this.
  9. Munpot42
    Munpot42 Senior Member
    1,391
    544
    Santa Monica, Ca. 90405
    With short trips, if you have a series of stops in a short trip, with the Prius, go to the one that's the greatest distance from your start and work your way back, gives the car a chance to heat up properly and stay warm on all the trips home.
    boricua likes this.
  10. wjtracy
    11,374
    3,609
    Northern VA (NoVA)
    Consumer Reports or somebody ought to devise a short trip MPG test. I am thinking Prius is not necessarily the best as Toyota chooses to make all Prii CARB certified. Presumably a hypothetical non-CARB Prius (better known as a FORD Fusion Hybrid) might do better MPG when cold, but not sure without data.
    #10 wjtracy, Dec 22, 2015
    boricua likes this.
  11. Montgomery
    Montgomery Senior Member
    2,254
    2,242
    Orange County, CA
    For me, short trips, bumper to bumper, hitting all red lights gives me 50 mpg. Going on the freeway gives me 47 mpg.
    boricua likes this.
