Mpg went down after air filter change and why that may be a good thing
Discussion in 'Gen 3 Prius Main Forum' started by Prius hacker, Jan 24, 2019.
  1. Prius hacker
    Prius hacker New Member
    New Braunfels texas
    I acquired My 2012 Prius three weeks ago. It had 218k miles and the ice was just replaced with a 30k mile ice from a donor car. The car is amazing and in every way drives like a new car. I’ve put over 4K miles since I’ve owned it with the only quirk being the infrequent prius cough particularly in cold damp weather. It has not used a discernible amount of oil in that time. I’ve just replaced the air filter that was quite dirty and appeared very aged with a fram and my mileage in early driving appears to have dropped from mid 50s to high 40s. I’m ok with that because I saw the original engine that came out of it melted a hole clean through the pistons. So my supposition is that somehow the dirty filter creates a lean condition that results in improved mpg yet higher engine degradation from higher cylinder temps and less lubrication for the rings. Thanks for any feedback.
  2. Greenteapri
    Greenteapri Active Member
    330
    387
    Cypress
    Congrats on your gen three acqusition.
    Do you mean melted or grenaded?
    I would try cleaning the MAF sensor, along with the throttle body, intake manifold, and egr system.
    #2 Greenteapri, Jan 24, 2019
  3. Prius hacker
    New Braunfels texas
    Idk I was shown the engine outside the car with a hole in the block about the size of a golf ball. Thanks for the suggestions, I’m gonna leave it alone as long as I’m getting factory numbers on mpg. I’m not convinced the hypothetical lean condition from a dirty oil filter killed the engine, or the previous owner was not monitoring oil level and burned out that way, it’s all speculation. My personal interest is not in max mpg but rather max engine longevity, btw the cough I described, basically ice startup stutter, likely will not present again. To early to tell though
  4. JC91006
    16,748
    8,554
    I'm the skeptical type that won't believe what a seller tells me unless there's proof the engine does in fact have 30k miles on it.
    Besides that, congrats on the Prius. Hope you enjoy it for years to come.
  5. Pluggo
    Pluggo Senior Member
    608
    533
    Folsom, Pennsylvania
    Welcome! A clogged air filter makes the fuel mixture too rich, as in too much fuel, not lean. The onboard electronics will try to compensate but they can only do so much. Excessive engine knocking from pre-ignition is the typical cause of a piston head burning through.
  6. Prius hacker
    New Braunfels texas
    I agree Logically the dirty air filter should have created a more rich mixture and therefore higher fuel consumption per mile , that’s the mystery because mpg went down, How could a more restricted air flow increase mpg? My interest is engine longevity, hypothetically does a high mpg engine wear out faster than a lower mpg engine?
  7. bisco
    51,732
    clogged egr?
    m.wynn likes this.
  8. Blackwing
    Blackwing Member
    102
    I'm getting this issue too. P0171 and P0420
  9. Eddie25
    Eddie25 Active Member
    496
    209
    MI
    Three weeks is hardly enough time to create accurate mpg figures, and that variance seems fairly normal to me. Maybe it's just been windier since you installed the air filter.
