MPGe
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Jonny Zero, Sep 8, 2014.
  1. mindmachine
    mindmachine Member
    394
    79
    Ohio
    2014 Prius Plug-in
    220 volt charging with my clipper creek EVSE is at 20 amps and that is 4.8kwh so I charge my i3 in about 5 hours from empty. So it saves me 14 hrs from empty. Thus the calculator reduces the gas usage due to the shorter recharging time. I could have opted for a 30 amp EVSE and that would have resulted in a 3.5 hr charging time from empty, but I would have had to put in a new 220 volt supply to my garage at the higher 30 amp rating. For me 5 hrs was ok and therefore I used what i had available.
    wjtracy likes this.
  2. Okinawa
    Okinawa Senior Member
    1,333
    320
    I sure would not change anything with summer electric rates at $80.00 per month.
