MSN Autos criticizes Prius for small gas tank!(?)
Discussion in 'Gen 3 Prius Main Forum' started by Sphyrna, Jul 21, 2009.
  1. rachaelseven
    rachaelseven New Member
    616
    212
    Adams, MA
    Agreed, but isn't that where the 2 gallon cushion comes in? I mean, you get to 500 miles at 10 gallons or so if you get the rated MPG, right?
  2. FL_Prius_Driver
    FL_Prius_Driver Senior Member
    4,319
    1,527
    Tampa Bay
    I
    What needs to be added to the discussion is the safety issue of carrying around a relatively huge amount of dangerous fuel for a car that does not need to haul it around. Next problem is where does the space get removed to increase the fuel capacity....less legroom anyone?
    Toyota has been in the business long enough to know exactly the best tradeoff of space, safety, cost, and functionality. As much as I would like to not stop at a gas station (ever), I would not have liked the extra cost and loss of space.
  3. wvgasguy
    wvgasguy New Member
    1,255
    185
    a
    The only "critism" I saw was a red "-" on tank size. It was a statistical comparison and indeed it is a "-". It got "+'s_ for FE.
    It's an observation that needed to be pointed out as many of us buying a Prius had indeed hoped for a range similar to the FFH. I personally would have liked to be able to get 600+ miles per tank (with a 47 mpg average)
  4. namasteflc
    namasteflc New Member
    47
    Georgetown Md
    This discussion will change dramatically when we begin talking about a 'total' Electric Vehicle. We wouldn't be talking about a 500 mile tank full, we will be grateful for a 100 mile recharge range. Be thankful for the blessings we have.
  5. qbee42
    qbee42 My other car is a boat
    18,058
    3,079
    Northern Michigan
    Fuel tanks are sized by range, not capacity. Except for special use, it makes no sense to drive around with excess fuel. It only takes up space and adds weight.
    Taking this to its limit, should we criticize darelldd's EV because it has no fuel tank?
    Tom
  6. OZ132
    OZ132 Member
    170
    Northern Indiana
    Picky Picky Picky!
  7. accordingly
    accordingly Member
    268
    63
    Madison, WI
    You are mistaken- fuel tanks are sized by capacity. Range of a full tank is a property of the car as a whole. You can't go into a parts store and ask for a 200 mile tank just as you don't go to the supermarket and buy a 2 day container of milk.
    Read the link posted in the OP- the metric in question is fuel capacity measured in gallons. In fact, range is a completely separate category where the Prius receives a plus.
    MSN has decided more is better, and though I would say there's no reason to cry about this mostly insignificant point it apparently it struck a nerve. If 20-30 pounds worth of fuel is so important to you, then don't fill your tank to full. With a larger tank at least you have more choice in determining your own range to weight ratio.
    The same point can be made for EVs- since the fuel needed for an EV is electricity, we'd have to know the amount of charge the vehicle can hold compared to other vehicles to make that judgment. Even if the vehicle in question is the most efficient EV on earth, it would be a negative if you had to stop and recharge every 10 minutes of use.
  8. ALS
    ALS Active Member
    590
    294
    Pittsburgh
    You also have a problem with stale gas if they had fitted the car with a wishful 18 gallon tank.
    For example me: I have 60 liter / 15.8 gallon tank in my soon to be departed 87 Volvo 740 Turbo wagon. I drive on average just under nineteen miles a day in the car. Now look at my situation with a new Prius.
    With my Volvo I fill up every 16-17 days at 20-21 mpg or 300 miles.
    Prius gets say 525 miles per tank / 18.75 miles per day = 28 days per tank. Guys that is four weeks or 28 days per tank of gas.
    If the Prius had a 60 liter /15.8 gallon tank that would extend the range to 750 miles or having to fill up every 40 days or close to every six weeks.
  9. bruceha_2000
    bruceha_2000 Senior Member
    3,054
    302
    Northwest VT
    2018 Prius Prime
    I think you missed Tom's point, though it would have been better said: The mfg's tank selection for a vehicle is sized by range. They aren't going to throw a tank in that would only get the vehicle 100 miles (unless an EV ;) ). Something between 350 and 600 miles seems to be the 'range'. An H2 has a 32 gallon tank to approach the low end of that range, the H3 23 gallons. The Prius has an 11.9 gallon tank to make the high end.
  10. wvgasguy
    wvgasguy New Member
    1,255
    185
    a
    I think everyone is reading too much into this. (Prius Paranoia?) The negative is just a comparison to the cars it is in comparison with. Maybe I missed it but I didn't see them hammering on the Prius. I simply saw a red "-". And as it compares to the other midsized cars it is indeed a significantly smaller tank. The rating was on capacity. It is a small tank regardless of the range and FE of the car. Small is small.
  11. wvgasguy
    wvgasguy New Member
    1,255
    185
    a
    I've never really understood the desire for owning an economy car when one drives less than 7500 miles per year.:confused:
  12. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    I wouldn't sweat the MSN review. It's actually very positive. The negative on the fuel tank capacity is just an automatic as they compare capacity to the average. That's no big deal. If you can't do the simple math of 50 mpg x 11.9 and figure out that you'll have superior driving range?
    The thing that bothers me is the idiot reviews from owners on MSN. 99% are fine, but you always get the idiot that reviews super low, with no explanation, (just a hater) or what I dislike, is the person that reviews negatively because they "almost" bought a Prius but discovered they liked Vehicle "B" better...The reviews are suppose to be from Owners, not people that "almost" owned a Prius. These two elements skew the ratings down. I don't care if you REALLY own a Prius and have criticism or rate lower, I just hate non-owners and plain idiots lowering the overall score just because they are stupid.
  13. ALS
    ALS Active Member
    590
    294
    Pittsburgh
    The 2010 Prius in the next six or seven years will replace my 97 960 as my dedicated highway car. Then I'll replace the Prius with a more efficient hybrid for around town.
    I drive down to Florida and back three to four times a year. That means 7500-10,000 miles a year gets put on my 960.
    So between both cars I'm racking up 16K-18K miles a year.
  14. The Electric Me
    9,083
    5,801
    Why not? First of all The Prius is a mid-size vehicle, suitable for a family, not a typical econo-box. Plus economy is good for anyone and everyone. It's all relative.
    Lifestyles and driving demands can also change unexpectedly. You can switch jobs, or move and suddenly you are putting many more miles on your vehicle.
    There's no minimum requirement for wanting to be economical.
  15. snead_c
    snead_c Jam Ma's Car
    667
    58
    Hendersonville
    Isn't the red mark for torque 105 lbs a little misleading as well since it only includes the ICE and leaves off the impact of the hybrid battery ?
  16. Sphyrna
    Sphyrna Priusite
    202
    180
    Miami, Florida
    My point, although I didn't articulate it expressly in the original post, is why would they rate the tank size AT ALL instead of the travel range? This car defies the logic of tank gallon capacity. It's like complaining that a microwave oven has no preheat capability. What matters is how quickly it cooks, not that previous technology had an option to speed up your cook time when using the older type oven and this one doesn't. Comparing travel range would have compared apples to apples against a corresponding measurement in a ICE-only car.
  17. Sphyrna
    Sphyrna Priusite
    202
    180
    Miami, Florida
    Given that you can buy ANY car you can afford (isn't this a great country!) and that there are other cars in the same price range with similar passenger/cargo capacities, isn't it enough to just like the Prius in order to buy it? I think so.
