mswtoyota's 2006 Black Prius mods
Discussion in 'Gen 2 Prius Accessories & Modifications' started by mswtoyota, Feb 1, 2015.
  1. Dxta
    Dxta Senior Member
    1,945
    770
    Lagos
    They seem to be same!
    What were you trying to achieve replacing the sway bar?
  2. mswtoyota
    mswtoyota Member
    42
    74
    Amarillo, Tx
    The Pontiac is about 4 mm larger. I was trying to stiffen up the suspension so it didn't wallow around so much in the corners without negatively impacting ride quality. I think the ride quality sucks enough as it is...
    SFO and Prius_Angie like this.
  3. Dxta
    Dxta Senior Member
    1,945
    770
    Lagos
    Thanks for the info.
    Did you also have to upgrade the shocks from the stock to something more higher, or something?
  4. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
    No you don't, though people here have upgraded both front and rear shocks.
    When replacing the front sway bar, be sure to get the brackets and bushings from the donor car.
    When replacing the rear sway bar, I took the larger bolts from the donor car and then added some thick washers for my install. Be sure to get the top and bottom orientation correct the first time around.
    Dxta likes this.
  5. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
    Could you please share a link to either of these mods.
  6. mswtoyota
    mswtoyota Member
    42
    74
    Amarillo, Tx
    Mikesvagen and SFO like this.
  7. mswtoyota
    mswtoyota Member
    42
    74
    Amarillo, Tx
    I did not upgrade struts, but I'm sure I need to as the originals only have about 275K miles or so on them now. Some adjustable coilovers would be nice if anyone wants to donate some to me ;)
    Mikesvagen and gta_ like this.
