Mud Flaps Install
Discussion in 'Gen 2 Prius Accessories & Modifications' started by TimMan, Jan 7, 2008.
  1. TimMan
    TimMan AC or Bust
    44
    Bucks Cty, PA
    I just rec'd my new mud flaps and want to find out if I should install them or have the dealer do it?
    If I do it myself, can I reset the tire monitoring?:confused:
  2. okiebutnotfrommuskogee
    okiebutnotfrommuskogee Senior Member
    1,813
    Tulsa, OK
    Seems to me that just taking a wheel off and then re-installing it will not upset the tire monitoring. The pressure sender is in the wheel. There is no physical connection to the car except the lugs.
  3. Ichabod
    Ichabod Artist In Residence
    1,794
    Newton, MA
    Yup, it's easy to do yourself and you won't mess w/ the TPMS. It might help to have a torque wrench to torque your lug nuts when you put the wheels back on. You don't have to remove the front tires, just turn the steering wheel all the way left/right when doing it.
    I did mine myself in <1hour. Others have also posted that they've done the install w/o removing tires by using a screwdriver/drill with an angled adapter.
  4. Jon the Chief
    Jon the Chief Jon the Chief
    50
    Wolverhampton UK
    Has anyone any idea how much drag mud flaps add, and what hit you get on MPG?
    Jon the Chief
  5. okiebutnotfrommuskogee
    1,813
    Tulsa, OK
    Don't know, mine came with them. I have wondered about that though.
  6. TimMan
    TimMan AC or Bust
    44
    Bucks Cty, PA
    Do you notice a difference in MPG?
    I hope it wasn't a waste of $$.:mad:
  7. Mr.07Prius
    Mr.07Prius New Member
    I installed a set myself and had no issues with taking the wheels off and putting them back on. You should be okay and they are easy to install. I think it might be actually harder to take the wheel off than installing the mud flaps. Good luck.
  8. Ichabod
    1,794
    Newton, MA
    It also seems to be fairly well accepted here that the mud guards present little or no impact on MPG. I don't want to bother searching for sources, but you can if you like :) When I put mine on I noticed no difference.
    Also, they stopped water/mud from splashing onto my pretty car, which is worth something... they also help to distinguish my car from the bajillions of other Prii in my area :D
  9. Rangerdavid
    Rangerdavid Senior Member
    1,362
    52
    Boone, North Carolina
    Three Touring
    had mine on for almost a year and a half. no hit on mpg at all. very good mod to save the Prius from dings and dents from road debris. very good investment IMHO.
  10. lenjack
    lenjack Active Member
    804
    114
    Pennsylvania USA
    While there has to be a mileage hit, it's so small as to be unnoticeable.
  11. Rae Vynn
    Rae Vynn Artist In Residence
    6,038
    707
    Tumwater, WA USA
    The MPG hit from the mudflaps can be completely compensated by installing the shark fin, which improves aerodynamics.
  12. TimMan
    TimMan AC or Bust
    44
    Bucks Cty, PA
    Gentleman and Ladies - thank you very much for your input!!!!
    Everyone have a great Army Day and do not forget to reenlist.
    Seriously, thanks a bunch.
  13. patsparks
    10,664
    567
    Adelaide South Australia
    There does not have to be a mileage hit from installing mudflaps and I don't believe there is. They go behind the wheels in a turbulent air area so they ride in the slipstream of the tyres. Toyota put a flap thing in front of the wheels which reduces drag by moving the air around the tyre, the tyre does the same for the mudflap.
  14. TimMan
    TimMan AC or Bust
    44
    Bucks Cty, PA
    Well, Bob's your Uncle!!!
    Great Answer!!!!:eek:
  15. BlackPri08
    BlackPri08 New Member
    50
    central Indiana
    I recieved my mud guards from "Prius Shop" this week. I'll be installing them this weekend. I'll try to take some pics.
  16. patsparks
    10,664
    567
    Thank you.
    Actually I have an aunty Jack but not an uncle Bob.
    That's "her" top left of this family reunion photo.
  17. TimMan
    TimMan AC or Bust
    44
    Bucks Cty, PA
    Wow! Your Uncle Bob sure is pretty...........:p
  18. patsparks
    10,664
    567
    "She" is my aunty.
    Any Aussies care to explain, I have to go to work.
  19. davebernier
    davebernier Junior Member
    Morrisville, VT
    I installed these myself in about an hour a year ago... No mileage hit as far as I could tell.
  20. n24005
    n24005 New Member
    West Milford, NJ
    About to install my mud flaps... I have not jacked the Prius before..
    Do I really have to use their jack? I have a standard roll around lever jack. Will I damage the jack point using it instead?
    Thanks,
    Jeff
    2008 Silver Pine Mica
